2003 Mustang GT
People w/ Vortech/Procharger, Need a picture
So I put on a couple different belts today. I had great luck with a Dayco Poly Rib, but I hit a deep puddle and it through my batterly light on real quick, then I noticed the belt was ripped alitle. Then 2 days later it tossed a rib.
So I bought a Dayco Poly Cog (they didnt have a poly rib) and it didnt like that, I guess it doesnt like the 90* angle cuts in the belt. So I bought a Dayco Poly Rib, It hit only 6psi, and it was screeching at WOT. I figured, bad belt. So I returned it. Now, I bought a Gates Micro V belt. First time it hit like 9psi. Then it only hit 5-6 and it was screeching at WOT. So, Ive narrowed it down to 2 things. 1 - A bad tensioner pulley, although I JUST put one on like 2 weeks ago. 2 - Its rubbing on the Alternator spacer. So I need a picture of how close the belt is to the spacer in the alternator. Mine is pretty damn close. And It doesnt screech until I go WOT, not 1/2, not 3/4. So Im wondering if theres some flex?? Idk.... heres my pictures ![]() ![]() Reps to whoever has pics!!
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2003 Mustang GT
Im probably just going to return my tensioner, and grind down the spacer regardless. But, Id like to see how close other peoples are.
Irregular
2001 Mustang Bullitt DHG
Jesus Christ dude, you have some shit luck with belts. Time for the On3 kit lol.
Vortech V2 Non I/C 377rwhp and 365 rwtq ![]() |
2003 Mustang GT
Dude I know. Its fucking rediculous. I considered it, but Id hate to just give up because of belt issues. I know I can fix it. I do understand running such a small pulley makes the chance of slip a lot higher. I want to go with a better intercooler and 3.12 pulley. But the re-tune price kills me.
I just looked at mine and mine is actually the same distance as yours. I measured it and its .30mm from touching the belt. If your belt is tight enough it wouldnt hit the spacer.
It could be 1 of two things. 1) your belt over stretched, but you replaced it. or 2) your tentioner is old and needs to be replaced. It may not be able to hold that tension at 5k anymore which is causing the slip. I'd try replacing the tentioner first and see what happens since they are pretty cheap.
2000 GT, 5.1L, Crank, Probe 23cc Pistons, Manly H-beam Rods, Arp Studs, Ported heads, Comp Cams XE270AH, 75mm TB, Plenum, Vortech v1 T-trim, Custom FMIC, Roush Stage 3 Kit w/rims, Spintech Mufflers, 3.73's, 60lbs inj, Duel GT pumps, SCT Maf. |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Since it sounds like your getting ribs cut off look at the power steering res bracket. I know mine was real close and that is a long stretch of belt that if any vibration in it will start cutting the belt
![]() bone stock from the factory! |
12.73@111.36
I'm running a ProCharger and I don't have an altenator spacer like that. My spacer is the ProCharger idler pulley itself. My belt doesn't go anywhere near the power steering bracket either. It is at least 3/4" away. I was having trouble with belt squeal when the motor was cold. It went away when the motor warmed up. Spraying belt dressing on it made it much, much worse. I noticed the tensioner was moving in and out as I worked the throttle from under the hood. It shouldn't do that. I replaced the tensioner with one from Autozone and the problem is fixed. It is rock solid, not moving at all when I work the throttle. My belt is now tight enough that if I strum the section between the altenator and power steering pump it sounds like a bass guitar string. I'm using the 1080K6 Autozone belt.
Note: I had to grind the belt guard off the new idler pulley. My original pulley didn't have one and it was hitting the ProCharger bracket. Also, I was having a lot of problems with shredding belts for a while. It was my pulley alignment.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2003 Mustang GT
I just replaced the tensioner and grinder down the spacer, no clearence issue, but its still screeching at WOT. Once I hit like 4000rpm. Only hits 7psi. I got a video ill try to upload it from my phone
2003 Mustang GT
Baker Jr.
procharger doesnt have that..just get a procharger bracket and headunit bro!!! everything else will work lol...can u change that pulley to a lil smaller one? why not run a reichard racing ultra grip pulley if your slipping. but yea i could see it hitting that and it holding against it a little and slipping or do a reichard racing a/c delete with manual tensioner bracket they have
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
2003 Mustang GT
Sounds pricey lol. Honestly I had best luck with dayco poly rib and drive rite belts. Im gonna go back to a drive rite.
Will to big of a belt cause that screech too? It seems like it always does that with a gates micro belt
Baker Jr.
If it slips more then sure..i only run gates micro v. There the best..but i hear ya. Ive had two belts peel apart and lose a rib back in the day but fine now. Now im 8 rib. Got it aligned nice and straight and a
2.8 RR pulley
2003 Mustang GT
It's gotta be slipping hard if its screeching like that I would think
12.85 @ 114
sorry dude, time for an 8-rib setup
![]() p.s. I think my TOB is going out again....
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon Last edited by 0949er; October 2nd, 2011 at 01:15 AM. |
Baker Jr.
Na not at his power. Spend the big bucks and get the thumper racing i believe tensioner..sexy too..more load
Baker Jr.
Or build a peice with a bolt and a idler and bolt it on somewhere as a manual tensioner and wrench er down lol
2003 Mustang GT
Okay I got it... I know I dont need 8 Rib because Ive been hitting 9-10psi. Just run into little issues because my dumb ass likes to change things when their working fine lol.
Took the spacer out, grinded it down, put a washer between the bracket and timing cover where the AC silencer hooks on, and used my old Drive Rite belt. That belt is the best one Ive ever used. It never stretched, always was reliable. Thats what Ill be getting all the time. The only one that I liked too, was the Dayco Poly Rib. I might try that again eventually. Not til after track season. I dont want ANY more issues lol. Heres some pics, looks hacked but I was losing my patience. I put on 4 belts since Friday night, and a new tensioner lol. Behind it is my Drive Rite belt, and the Gatorback belt. My car never liked a belt that wasnt just straight groves. Anything with angle cuts, it didnt not work. ![]() ![]() ![]()
2003 Mustang GT
Oh does this sound noisy to you guys? I know V1s are loud, but Idk, maybe Im just being paranoid
12.73@111.36
I've been thinking about your problem. I think its pulley alignment. A bigger belt squeals. A tight belt shreds. Why? Perhaps its because the tight belt can't jump ribs. That washer between the bracket and timing cover might get your pulleys better aligned. That was part of my problem. To align the supercharger pulley with the altenator pulley, I used a straight edge (completely flat metal ruler). I layed it flat across the altenator pulley and compared it to the supercharger pulley. When I first did it I found the supercharger bracket was on crooked. That made the pulley crooked. It was lined up on the side closest to the altenator but off almost one rib on the far side.
P.S. Does your waterpump pulley have a lip on it? I'd never be able to get a belt over it. It's too tight. My Miezere idler pulley is smooth. My belt is also tight enough that I don't think I could slip it over the altenator pulley either. I have to slip mine over the smooth tensioner pulley to get it on (the belt guard has been removed).
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; October 2nd, 2011 at 11:43 AM. |
12.35 @ 116
My gatorback belt rubbed on the spacer for a little bit until the belt itself was worn down...but it's still working like the day i installed it. Sorry about your luck man!
Vortech boosted MMR900 and supporting mods 420rwhp 410rwtq loaded Mustang Dyno Turbo boost in progress |
Threads Similar to: People w/ Vortech/Procharger, Need a picture
| Procharger, KB, or Vortech? | Chris02 | 99-04 | 39 | April 27th, 2010 10:00 PM |
| Going Vortech or Procharger | Shaun03GT | 99-04 | 44 | November 17th, 2009 03:26 PM |
| vortech or procharger | bige | 2005 - 2010 | 1 | June 19th, 2008 09:12 AM |
| Procharger or Vortech??? | shurb125 | 5.0 Mustangs | 9 | February 13th, 2008 01:34 PM |
| Procharger vs. Vortech | 9stang1 | 5.0 Mustangs | 9 | December 7th, 2006 06:37 PM |
