2002 mustang gt Cruise control doesnt work need help!!!
Old October 1st, 2011, 09:39 PM   #1
black02pony's Avatar
2002 mustang gt
12.6 @ 25mph
black02pony is on a distinguished road
Like the title says 2002 mustang gt 5 speed cruise control doesnt work . This car has been wrecked by pre-owner . I have checked the wires to cruise control. to make sure it was hooked up. I also checked the cable linkage and still doesnt work . im going to check the fuse . All i need from ya'll is to what else to check. since ive had the car is 2009 the cruise has not worked and i have been putting it off.
FoMoCo " The Best Never Rest "
Old October 1st, 2011, 09:47 PM   #2
2002 mustang gt
12.6 @ 25mph
im gonna check the switches in the steering wheel to cause they might of came disconnected when put back together from replacing the airbag .
Old October 1st, 2011, 10:36 PM   #3
2002 mustang gt
12.6 @ 25mph
checked fuses, checked cruise control buttons, harness and all are ok.
Old October 1st, 2011, 11:30 PM   #4
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
does the horn work? You might have a broken clockspring
Just because your cars loud doesnt mean its fast
Old October 2nd, 2011, 12:41 AM   #5
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
There is wiring in the steering column that probably got either disconnected or damaged. I had an airbag light on and that was the cause, cruise control also didn't work. The cruise control is the same tab. Would make sense if you had it apart. Could be the problem. I honestly forgot the name for it. Sorry!
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old October 2nd, 2011, 02:55 AM   #6
Maverick530's Avatar
2001 Mustang GT Vert
Average
Maverick530 will become famous soon enoughMaverick530 will become famous soon enough
mine doesnt work either :/
but what i notice is right now im missing the cover for the ON/OFF switch, i guess thats the one on the left side, and when i hit both of the bottons at the same time, my horn honks haha
Old October 2nd, 2011, 11:20 AM   #7
2002 mustang gt
12.6 @ 25mph
horn works so its not the clock spring. and the wires behind the air are good . im gonna work on it today. but the airbag light isnt on ither
Old October 2nd, 2011, 02:48 PM   #8
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
There's also a switch on the clutch pedal that causes the cruise to shut off when the pedal is pushed. Might check that.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old October 2nd, 2011, 03:06 PM   #9
2002 mustang gt
12.6 @ 25mph
well i checked it cause a guy on a older thread said you can pull up on it should work and it also that switch works as the safety feature where it willnt crank without the clutch petal depressed and i know it works for that and i also pushed it down with my finger and i can hear the contacts engauging . the brake switch works cause i still have brake lights .
Old October 2nd, 2011, 06:44 PM   #10
PRODUCTIONMAN's Avatar
PRODUCTIONMAN is on a distinguished road
ive got the same problem; bought my car a year ago and also been puttingit off. I plan on pulling the driver side front inner fender liner where the actuator is. According to the service book you can check resistance I believe to see if that unit is bad. Have you done that?
Old October 2nd, 2011, 07:00 PM   #11
2002 mustang gt
12.6 @ 25mph
Never done that before worked at ford 4 years and i'd just replace it . im thinking about getting the whole setup off ebay and putting it all on but i dont want to if i dont have to . But if you do yours ill find out if mine is bad . or you could tell me how-to . im ets ing out the army in a month so im real busy and barely ever have time to mess with the stang . but anyway .
Old October 2nd, 2011, 08:41 PM   #12
2002 mustang gt
12.6 @ 25mph
just another question why does my inner brake lights not work and i see alot of cars just like mine . i have new bulbs in it just wondering .
Old October 3rd, 2011, 09:41 AM   #13
2002 mustang gt
12.6 @ 25mph
any ideas i guess ill get a test light and a multi meter and figure it all out
Old October 3rd, 2011, 09:33 PM   #14
gdl
From the factory, the inner bulbs don't light up with the brakes or turn signals. Here's a site that tells how to enable them:
Mustang Six Brake Light Conversion
Or you can do a sequential signal kit.
Old October 3rd, 2011, 10:37 PM   #15
2002 mustang gt
12.6 @ 25mph
thats weird lol i never knew that
Threads Similar to: 2002 mustang gt Cruise control doesnt work need help!!!
2002 GT Clicks once, then doesnt start? Miller220 99-04 15 August 16th, 2010 10:04 PM
HELP my gas guage doesnt work Nicos2001GT 99-04 5 July 12th, 2010 11:06 AM
aluminum ds doesnt work 06dkkiser 2005 - 2010 V6 16 September 5th, 2009 09:30 PM
Shit just doesnt work out SoC@L MuST@ng dRivER Southeast 2 September 8th, 2008 04:32 PM
Help Cruise Control Dont Work! mygt350r 2005 - 2010 9 April 10th, 2008 06:08 PM
