255lph max horsepower - Page 2
Old October 7th, 2011, 08:30 PM   #21
MT0911's Avatar
99' Vette, 02' Mustang GT
MT0911 has a spectacular aura aboutMT0911 has a spectacular aura about
iTrader: 8 reviews
Just pick up a set of 60lb injectors, they should get the job done for you with both power goals. For the pump, you have a few choices but if all you want is 450 to 475 I would just get an svt focus pump (95 bucks brand new) and a BAP, you should be just fine with that. Other good options are to do an 03/04 Cobra twin pump and tank swap OR a GT supercar pump and modified FPDM.
But if you're trying to save some bucks and all you want is around 380-390 (before the block), get the SVT Focus Fuel Pump and some 60 lb injectors, and then when you shoot for 500 WHP (of course with a forged bottom like you said in the future) then pick up a BAP and you should be all set. This is also probably the cheapest solution lol but it will work well.
'99 SVT Cobra - 283 C.I. WAP Forged Block, HP Custom Blower Cams, Novi 2000rr (8-Rib) + 20 psi, RPM T-56, SRA Swap
'99 C5 Corvette FRC - H/C/I/E + Suspension
'02 Mustang GT - Exhaust, 4.10's, Suspension SOLD
Old October 11th, 2011, 11:27 AM   #22
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Cheapest bang for the buck.
03/04 Drop in
Knock out your baffle, use your tank.
Good to 450+rwhp.
Add a BAP later, ive done over 650rwhp on this. No wiring upgrades, no FPDM upgrades. Just pumps and BAP.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Threads Similar to: 255lph max horsepower
255lph fuel pump for a 98 Fuego Authorized Vendors 0 August 17th, 2011 11:36 PM
Tre 255lph Fuel Pump BLUE91GT 5.0 Mustangs 9 September 12th, 2009 02:54 AM
255lph & 8.8 axle install advice sniperd 5.0 Mustangs 8 August 7th, 2009 01:41 PM
