coolant question - how to determine system is filled and done
Old October 3rd, 2011, 06:46 PM   #1
2001 Saleen S281 S/C
v6dave is on a distinguished road
heres what i did:
-drained and flushed whole system
-filled whole rad with coolant
-ran car with heater on max w/o raditor cap for a few minutes.
-car made some bubbles by radiator cap
-large hoses seemed squishy and void of coolant
-after a few minutes of running the car got to operating temperature and started atrociously spewing mass amounts of coolant out the radiator filler hole (cap was still off)
-turned car off, because that's not good and it was making a mess
My two questions:
-So am i done? Do i just put the cap back on and drive? or did i put too much or too little in? how do i determine im all good?
-Also how do i know if air bubbles are in the system, will it hurt the car or cooling system in any way?
2000 V6 Mustang (DD)
2001 Saleen S281 supercharged
Old October 3rd, 2011, 07:34 PM   #2
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
if there is air in the system the car will over heat. not good.
sounds like the coolant was being pushed out of the radiator...i would put the cap back on, let the car cool a bit and then pull the cap and top it back off with coolant...
once you get heat inside the car it usually means the air is out...but i would take it for a short drive and keep a close eye on the temp guage because this isn't always the case
cams + 150 shot
Old October 3rd, 2011, 08:29 PM   #3
well i think i got the air out, there was no overheating, heat works 100% I also drove for about 5 min and the temp gauge stayed exactly in the middle. Should i be good as long as i periodically check the levels?
Old October 3rd, 2011, 09:34 PM   #4
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
should be fine. probably got the air out after you shut the car off and it cooled...
just make sure the radiator is full...
cams + 150 shot
Old October 3rd, 2011, 11:06 PM   #5
JustRight's Avatar
01 GT Conv
JustRight is on a distinguished road
I know this is going to sound crazy, but jack the front end up while purging the air---it helps.
Official member of the anti ethanol-laced gas crusade.
Threads Similar to: coolant question - how to determine system is filled and done
Coolant System Flush WhiteLies 94-95 3 June 15th, 2010 07:46 PM
question on wrongly filled title mlessor96GT The Clubhouse 2 May 27th, 2009 10:42 PM
How do you determine what cam? bossman69 Classic Mustangs 11 October 18th, 2008 06:39 PM
operation clean the coolant system KhaosGT 99-04 0 June 14th, 2008 04:18 PM
need a little advice (coolant system 01 GT) HMUSN General Tech 4 March 21st, 2007 10:57 PM
