#1 | |
Disturbin' The Peace
2003 Mustang GT
![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
LSD noise
I took my dad around for a drive so he could hear the noise going on with my car. As I turn and slow down its a clack clacky clack clacky noise. And it sounds like it is coming from the trans, but he says its more likely the diff. Which would make sense because of the LSD transfering power when turning. Would a different weight oil than from factory cause the LSD to start acting up like this?
I was recommended 80-90 lucas gear oil from a guy at autozone, I picked up a bottle of friction modifier too.(<--mistake listening to anything they have to say) What is the weight from the factory? 90-130? 75-140?
![]() 2003 Mustang GT STD 259rwhp 298rwtq
The Mean Green
I believe 75-140 was the stock weight in mine but i doubt the oil would give you the noise. I always add the friction modifier too. But I'd start by putting the car on some jack stands and checking the u joints, suspension bushings, and spin everything to check for excessive play. Might try runing if the car in gear to listen for the noise.
12.73@111.36
My owners manual says 80w-90.
http://shnack.com/docs/2000_owner_guide.pdf
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
75-140 is what the tag on my Diff Cover says
I like boobs!!!
2000 GT convertible
dunno
Always go with what's in your owners manual (or on your tag on the rear end if it's stock). And also +1 to the friction modifier. When I used to work in a shop years ago I remember having similar problems in an ambulance when I forgot to add the modifier (we had a contract to do all the maintenance for the local ambulance company). I was young and didn't know better, but apparently they type and weight of the rear end oil is very important.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
Threads Similar to: LSD noise
| Odd Noise | N29468 | V6 Mustangs | 10 | June 23rd, 2011 09:44 PM |
| Too much noise | tucker33 | 99-04 | 16 | May 14th, 2011 10:21 PM |
| Camshaft Phaser Noise - Engine Noise - Help! | xxxcobraxxx | 2005 - 2010 | 6 | May 27th, 2009 09:20 PM |
| Noise Help | AMmuslGT | 2005 - 2010 | 3 | April 22nd, 2009 08:54 PM |
| 2005 auto mustang vibration noise/ rumbling noise | ozan169 | 2005 - 2010 | 4 | March 13th, 2007 05:31 PM |
