Cams with Trick Flow Heads - Forums at Modded Mustangs
post #1 of 14 Old October 7th, 2011, 08:42 AM Thread Starter
I like boobs!!!
NickPohlAandP's Avatar
So I've decided to bite the bullet and go with the Trick Flow heads. I know that the valves are moved in these heads, which supposedly reduces PTV issues. My question is will I be able to run my COMP 270 cams correctly installed without notching my pistons? I ran them on the stock shortblock with the stock heads for a long time but I don't know if they were degreed differently to reduce the PTV issue. Thanks for your input everyone.
'00 V6 being gutted for real fun! Fixing where I went wrong with my last 2000
'04 V6 for my stepson
'27 Ford T Sedan, sold
'12 GT, Roush Exh, Steeda 101mm CAI, SCT Tune, MGW, 388 WHP 375 WTQ, Sold
'00 GT Vert, Built, Sold
NickPohlAandP is offline
post #2 of 14 Old October 7th, 2011, 09:25 AM
Yes the revised valve position should give more than enough PTV clearance for the comp 270's.
cstreu1026 is offline
post #3 of 14 Old October 7th, 2011, 11:44 AM
MikeJones's Avatar
Those heads give tons of room for big big cams. Hell. I'm selling a set of 580/.580 trickflow stage 2s that were designed around that head. I'm asking dirt cheap too. 350 shipped.
Mod6 Eagle Melling
Bigbore Bullet Cams Meziere
Kooks Probe Pistons
Thanks to NA SVT and NeverEnough
MikeJones is offline
post #4 of 14 Old October 7th, 2011, 01:12 PM
slow02gt's Avatar
Send a message via AIM to slow02gt
yes they will drop right in...you may want to get some better cams though with the trickflows....
a bunch of shit lol..
slow02gt is offline
post #5 of 14 Old October 7th, 2011, 01:16 PM Thread Starter
I like boobs!!!
I've got the cams. I know they will fit. I am wondering about PTV issues with my cams. No big deal though. I called Trick Flow and they said they are good for their stage 2 cams with no PTV issue. Those have a .580 lift. Mine have a .550 lift and the intake duration is exactly the same between the two. My exhaust duration is 4 degrees more than the Trick Flow cams, so I'll be fine. Crisis averted.
post #6 of 14 Old October 7th, 2011, 02:00 PM
slow02gt's Avatar
good deal...even though i said they would drop right in in the first place
slow02gt is offline
post #7 of 14 Old October 7th, 2011, 02:22 PM
MikeJones's Avatar
I also said that I was selling trickflow cams. .580/.580...... 350 shipped.
Mod6 Eagle Melling
Kooks Probe Pistons
post #8 of 14 Old October 7th, 2011, 04:04 PM
MikeJones PM sent.
Drive it like you stole it
99GT35thLE is offline
post #9 of 14 Old October 7th, 2011, 06:19 PM
MikeJones's Avatar
Returned.
Mod6 Eagle Melling
Kooks Probe Pistons
post #10 of 14 Old October 8th, 2011, 01:42 AM
MacDizzle's Avatar
best price? lol
damn, those would go good with my new MMR 750 SE MMR Motor
MacDizzle is offline
post #11 of 14 Old October 8th, 2011, 01:48 AM
Cone Killer
If you go with .580 lift cam, make sure to go with the non track heat springs as they are only rated to .550
Mods in garage
cbjohnson9 is offline
post #12 of 14 Old October 8th, 2011, 05:07 AM
I think you meant to say "go with the track heat springs" if using a cam with more than .550 lift.
post #13 of 14 Old October 8th, 2011, 08:26 AM
MikeJones's Avatar
Yup, springs and even the little shims.
Still for sale btw..
Mod6 Eagle Melling
Kooks Probe Pistons
post #14 of 14 Old October 8th, 2011, 11:37 AM
Cone Killer
No I meant what I said. The track heat springs are rated at a lower lift that the non track heat:
http://www.trickflow.com/partdetail....4&autoview=sku
Trick Flow® Twisted Wedge® Track Heat® 185 Cylinder Heads for Ford 4.6L/5.4L 2V: TFS-51910004-M44 - trickflow.com
Trick flow must've changed their springs or are advertising differently cause when I bought my set of heads, the springs were rated at .580 and .550, now they're .600 and .580.
Mods in garage
Human Verification
