2001 mustang gt
Rough idiling and exhaust smoke
I have a problem 3 cylinders my car is idiling rough and when i start it it blows smoke that disapears fast
I checked my spark plugs and connections but all seems good exept when i disconnect each spark plug one by one 3 of them nothing happens im not sure if i blew a fuse or the connection to the coil is not working wich may not be burning the fuel and causing white smoke The ingintion coil works i switched them around and all works fine just 3 connections from the harnes dont seem to be working and my check engine light is flashing Any help is apreciated |
swap the plugs, see if it follows, then swap injectors. If nothing changes when swapping those around, run a compression check
2000 GT 'vert
does it have COP or wires? What year is your car?
white smoke is usually coolant, is it white or just vapor that comes out in the morning?
oil look like a milk shake? open the coolant res. and see if it bubbles while the car is idling
2001 mustang gt
It has cop its 01 and i dont think its a head gasket no milky Colant oil is fine i switched around the coils but not the injectors and i also switched the spark plugs but nothing
And the smoke is like vapor it happens when the car sits for a while and i turn it on and thick cloud of smoke comes out but disapears fast it smells kinda like chalk Could it a fuse |
if it was a fuse youd have all or none working.
2001 mustang gt
What can cause one of the coil conections from the wiring harness not to work beacuse i think thats whats happening the conections from the wiring harness arent working any ideas on how to check them
grounds
run a compression check also, make sure the holes are good
2001 mustang gt
Well now its bloeing more smoke i added some oil and its throwing more smoke i think its just vapor but what can cause this and its still got a rough idle
2003 Mustang Mach 1
Flashing "Check Engine" light usualy mean damage to the Cats is or is about to occur. And if your not getting spark and all that fuels not being burnt and is sent down to your Cats..that could get nasty. If you have a lot of white smoke that could be a blown head gasket which would also damage your Cats if there is a lot of coolant leaking past getting sent to your cats. But check all of your connections under the hood! One time I left the Mass Air Flow Sensor unpluged when I took my air filter off to Reoil it and my car smoked and had a rough idle. But when you say its smoking..does that mean all the time or does it somewhat stop when you drive it a while.
Nathan 2003 Mach 1 (Azure Blue) Eton Detroit Trutrac 31 spline, 31 spline Strange axles, 4.10 gears, Caster Camber Plates, Adjustable Struts and Shocks, Short Throw, JLT Intake, Flomasters, Magna Flow X Pipe |
flashing check engine is for a missfire
2001 mustang gt
Yes the smoke seems to go away after heating up but when i start the car it blows a small
Cloud of white smoke i deafenetly dont think its a head gasket i just had them replaced 2 months ago and no signs of oil in coolant and coolant in oil Could a bad fuel injector cause this i did a check on the spark plugs by unpluging each one when the car is on to see if engine starts shaking on the left side two of them did nothin when i unpluged them And on the right side one did nothing so i switched the ignition coil and spark plug to see if problem followed but nothing the problem was still in the same place So the next thing is the F/I can they cause the engine to idle roughly if not working properly |
swap injectors from a working cylinder to the ones missing
13.2
ive blown my head gasket and didnt have milky oil , it wasn't making past the piston ring, also how many miles are on your car, what do the springs on your coil packs look like? white and corroded like dirty battery terminals. white smoke is usually coolant/water bluish grey tends to be oil based chemical burning off black is to much fuel. correct me if im wrong that just been my past experiences. but though you dont want it being a head gasket might look into it before taking any more damage. hate to get cylinder wash.
2001 mustang gt
But my coolant level is the same im going to switch injector to see if the problem follows
2001 mustang gt
Seems it might be my injectors just switched them around and. The ideling got a litle better and i see less smoke
One of the injectors was cracked from the tip and on the left side seems the fuel rails were loose |
#18 | |
2002 mustang gt
![]() iTrader: 1 reviews
Rock stock
2005 Stage 1 Roush
My car did this when i let it sit overnight periodically, turned out to be a bad valve seal. I doubt that's the issue but its worth a thought
2003 Mustang Mach 1
My bad "number1gt" and "86er", When i was in Auto Technology School my instructor said that when the chech engine light was flashing it was damage to the Cats is or is about to happen and to stop the car immediatly...Maybe I missunderstood..But thank you two for correcting me..I love to learn..I'm glad you found out it was the injectors GtUnit. thats much easyer and cheaper fix then Head gasket or Valve seal..lol
Threads Similar to: Rough idiling and exhaust smoke
| 2006 Mustang GT Exhaust Smoke | glank09 | 2005 - 2010 | 10 | September 27th, 2011 04:02 PM |
| blue exhaust smoke | Mineral Gray GT | 99-04 | 12 | May 28th, 2011 05:35 AM |
| White smoke coming from exhaust? | Hull1990 | 99-04 | 12 | April 25th, 2011 08:30 PM |
| clouds of smoke from exhaust? | 006leenstang00 | 99-04 | 0 | January 11th, 2011 02:32 PM |
| White Smoke from Exhaust | GTXRacing | General Tech | 3 | May 21st, 2006 02:12 PM |
