Low Boost - Page 2
Old October 10th, 2011, 09:09 PM   #21
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
LOL toss that bypass in the trash and get a real one.... Those are pretty good for 8lbs or so but after 10lbs you need to step up. Surprised you dont have any compressor surge.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old October 10th, 2011, 09:11 PM   #22
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
No compressor surge at all It seems to be working great!! I can barely hear it blow off a little when i really get on it.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old October 10th, 2011, 09:35 PM   #23
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Originally Posted by SSG Pate View Post
I had a 107.5 it seemed to loose as the tensioner was almost all the way extended. The 107 dosnt stress the tensioner to bad looks about right to me.
You should be good with that belt. 106.5-107 for that small of a pulley. The guy I bought my 3.12 from, which will be going on with the intercooler, was using a 107" Dayco belt.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old October 10th, 2011, 09:36 PM   #24
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
This pisses me off reading this stuff. I cant run smaller then 108" without either wearing my tensioner out fast, or tearing a rib off my belt.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old October 10th, 2011, 09:38 PM   #25
blownstang's Avatar
Ya that bypass isn't much better than the stock Bosch one. It jus has a metal casing instead of plastic. I think Forge makes it. You shouldn't really hear that bypass becauase your recirculating the air. For 12psi + you should step up to a Vortech Mini Race/Maxflow or the Vortech Mondo if you'll want more boost in the future.
Old October 10th, 2011, 09:38 PM   #26
blownstang's Avatar
lol... i don't know man.
Old October 10th, 2011, 09:40 PM   #27
SSG Pate's Avatar
Looks like for now 12 PSI is my max boost, now that I just bought an intercooler it will go down even more.
Old October 10th, 2011, 11:30 PM   #28
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
The numbers were 431/407 on an auto non intercooled.
That would be 458/432 through a manual transmission. I don't know but that sounds pretty good for 12 psi.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old October 10th, 2011, 11:35 PM   #29
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Sounds "okay" Idk, Bullitt5566 made 515rwhp with a V2, MHS stage 1 cams, and longtubes, and 11psi. Stock heads, stock bottom end.
Old October 10th, 2011, 11:37 PM   #30
SSG Pate's Avatar
Well Im buying a few things that I hope will bring these numbers up a bit!
Old October 10th, 2011, 11:43 PM   #31
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I think it will man.
Old October 10th, 2011, 11:45 PM   #32
SSG Pate's Avatar
I think it wil too I hope this get me to that 500 now!!
Old October 11th, 2011, 12:35 AM   #33
blownstang's Avatar
Not really for having blower cams and an Edelbrock intake. There are three guys by me putting down 440-470rwhp on stock shorblocks with cams and 9-10psi intercooled through manuals.
Old October 11th, 2011, 12:38 AM   #34
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Maybe the motor just needs some more break in time. What kind of cams did you go with?
Old October 11th, 2011, 08:36 AM   #35
12.73@111.36
You have a stroked 4.75L motor. What compression ratio did you get?
Old October 11th, 2011, 11:52 AM   #36
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
Originally Posted by Nitmare67 View Post
SI trim should be making north of 15lbs BUT BUT. Everyone is getting caught up in boost and what THEIR motor does. We dont know what your cam specs are, how much overlap there is, how free flowing the heads are, exhaust system.... The Vortech intake is not THAT bad and IS BETTER THAN A PROCHARGER INTAKE. Procharger intakes may flow a little better but they suck hot air under the hood (not good). I didnt read what kind of maf your running but an HPX would work awesome (I run one in a very strange setup) and then just make your own power pipe. Should cost you about 75 bucks. You wont need any fittings on it if your blow through.
restriction in the heads, cams, exhaust would cause a higher boost reading as the air is not going through the engine as efficient.
Old October 11th, 2011, 07:33 PM   #37
blownstang's Avatar
I believe he went with MPH. Usually you see 65-80rwhp gains with these.
Old October 11th, 2011, 07:50 PM   #38
Obviously..... thats exactly what I meant...
Old October 12th, 2011, 06:54 AM   #39
SSG Pate's Avatar
I dont buy the restriction in the heads yet at my power level maybe if I was at 500 Plus I could see it, but not at stock power levels.
Threads Similar to: Low Boost
Boost ? fsttang96 96-98 9 February 28th, 2011 08:26 PM
Boost? Corpsman 2005 - 2010 54 August 30th, 2010 06:09 PM
Only 7 lbs of boost? bandity2k00 99-04 19 June 11th, 2010 11:11 AM
how much boost stangdriven 4V / SVT 2 March 27th, 2009 02:08 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 09:56 AM
