Low Boost
Old October 10th, 2011, 04:26 PM   #1
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Low Boost
Hey guys, this weekend at the dyno I was only able to produce around 12PSI on a 2.87 pulley non intercooled which yielded some pretty low numbers. Called Vortech today to see if there might be an issue with my blower they concluded NO, And after checking my serial number I found out that I bought the SI trim V-1 instead of the V-1 S trim I thought I had. Even Vortech concluded that my boost level seemed low. The boost build throuout the RPM and stays steady around 11-12 PSI. I should be much higher then that an ideals? I am still on the Stock vortech inlet,. but even at that there is something going on should be higher boost then I am getting.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old October 10th, 2011, 04:35 PM   #2
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
The stock Vortech intake could have a hard time keeping up. The acordian hose sucks, and its pretty restrictive. I say, get a powerpipe, or make your own. stal has a nice write up. Even a Procharger intake setup is better then the Vortech.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old October 10th, 2011, 05:40 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Make a dyno pull without a filter and see what happens
Old October 10th, 2011, 06:06 PM   #4
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Oh man. That's even worse. Si trim should be pushing close to 20 psi with that pulley.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old October 10th, 2011, 06:17 PM   #5
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
What kind of belt? I know u said 107" long that could be to tight and cause slip. I run a 108" drive rite from advanced and works great. A lot of people run 107.38 gatorback on a 2.87
Old October 10th, 2011, 08:00 PM   #6
SSG Pate's Avatar
I have a 107 belt and it seems to be just right, Now I called vortech back and they told me it was just an S Trim again I was like shit which one is it. It dont see to be slipping cause the boost stays constant.
Old October 10th, 2011, 08:02 PM   #7
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Try running a Drive Rite 108" Belt, see how it does. If its worse, just return it. Ive returned SOOOO many belts and tensioners with no issues or reciepts lol
Old October 10th, 2011, 08:02 PM   #8
SSG Pate's Avatar
I will be buying a power pipe tonight to see if the Vortech intake is the culprit. 430 Is low numbers though. I am also going to look into a intercooler, but dont know where to start on that.
Old October 10th, 2011, 08:04 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
That is quite low for a v1si trim. Even though it has a low step ratio it still should make 17-18# non ic. I would watch your boost gauge close cause of the needle looks like it is jumpy it could be a boost leak or belt slip. That small of a pulley can cause slip
bone stock from the factory!
Old October 10th, 2011, 08:11 PM   #10
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Thats what Im saying.
Old October 10th, 2011, 08:16 PM   #11
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
SI trim should be making north of 15lbs BUT BUT. Everyone is getting caught up in boost and what THEIR motor does. We dont know what your cam specs are, how much overlap there is, how free flowing the heads are, exhaust system.... The Vortech intake is not THAT bad and IS BETTER THAN A PROCHARGER INTAKE. Procharger intakes may flow a little better but they suck hot air under the hood (not good). I didnt read what kind of maf your running but an HPX would work awesome (I run one in a very strange setup) and then just make your own power pipe. Should cost you about 75 bucks. You wont need any fittings on it if your blow through.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old October 10th, 2011, 08:33 PM   #12
SSG Pate's Avatar
Well none the less there are stock cars with stock heads making more power then me so Im not pointing at the heads now I checked all connections today everything was tight. As far as the gauge went it is a good solid boost reading!! I am going with a power pipe, And looking towards an intercooler although this will drop BOOST, I think I can gain some Power!!
Old October 10th, 2011, 08:34 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
I would not be worried about low boost numbers if the hp was there to support it. Last build I did put down 458 hp at 5500 rpm 16 degrees timing and 8#the of boost. Sure it was a 5 speed but that was a standard bore/stroke motor with ported heads and stock cams
Old October 10th, 2011, 08:34 PM   #14
SSG Pate's Avatar
I had a 107.5 it seemed to loose as the tensioner was almost all the way extended. The 107 dosnt stress the tensioner to bad looks about right to me.
Old October 10th, 2011, 08:36 PM   #15
SSG Pate's Avatar
The numbers were 431/407 on an auto non intercooled.
Old October 10th, 2011, 08:36 PM   #16
stal94gt's Avatar
2003 mustang v6 ;)
slow
If your still using the stock bosh bov check it cause it could ne damaged
Old October 10th, 2011, 08:38 PM   #17
SSG Pate's Avatar
I have another Bypass valve that seems to be working just fine I have a stiffer spring in it for hogher boost
Old October 10th, 2011, 08:41 PM   #18
stal94gt's Avatar
2003 mustang v6 ;)
slow
With sc cars you don't use stiffer springs since they need to vent at idle and part throttle
Old October 10th, 2011, 08:49 PM   #19
SSG Pate's Avatar
Here is the Bypass valve I am using, I have the middle spring in for like 10-14lbs boost
BYPASS DIVERTER VALVE VORTECH PAXTON SUPERCHARGER | eBay
Old October 10th, 2011, 08:53 PM   #20
stal94gt's Avatar
2003 mustang v6 ;)
slow
Springs are rated for hg. Turbos require stiffer springs so they don't get sucked open at part throttle allowing for crap to get sucked in. Sc cars vent out constantly so the bov spring needs to be light so it stays open.
Threads Similar to: Low Boost
Boost ? fsttang96 96-98 9 February 28th, 2011 08:26 PM
Boost? Corpsman 2005 - 2010 54 August 30th, 2010 06:09 PM
Only 7 lbs of boost? bandity2k00 99-04 19 June 11th, 2010 11:11 AM
how much boost stangdriven 4V / SVT 2 March 27th, 2009 02:08 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 09:56 AM
