2004 mustang GT
![]() iTrader: 7 reviews
Nitrous
So I have been kicking around the idea of getting nitrous I want to run a 75 shot. My questions are what are the cons of nitrous? and I see all this talk about using window switches and wot can someone inlighten me on the purpose of a window switch and wot? thanks
Flowmaster super44's, 70mm frpp TB, C&L plenum, K&N cai,UDP,SCT SF3/X3, TR3650, short throw shifter, Mac O/R H pipe Waiting to install vortech v2 s trim |
04 mustang gt
7.21 @ 98
Wide Open Throttle switch means it sprays when you go WOT
window switch means you set the rpm range in which you want it to spray...3,000-6,000 rpm's for example. cons are getting the bottle refilled.
![]() cams + 150 shot |
2004 mustang GT
Ok I really appreciate the info another question can I just have it on a button so I can push it when I want it or is that bad news? O and I heard something about dyno tuning is a must and you have to retard the timing but doing that makes them doggy when not running the nitrous is there any truth behind that?
04 mustang gt
7.21 @ 98
you can spray a 100 shot no problem on the stock tune. that means stock timing and no dyno tune required.
just get a set of ngk tr6 spark plugs (one step colder). i wouldn't run the kit on a button. let it bog or hit the limiter just one time and intake could very well go kaboom
#5 | |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
so aside from a basic kit, you really should look into buying a window switch a bottle warmer and depending on where you mount the bottle you will want a safety blow-down tube (if its behind the front seats) or a remote bottle opener (if its in the trunk) it adds up once you start buying the extras, thats the biggest down side IMO.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
2004 mustang GT
Ok so if I run a window switch does that mean every time I hit those rpm's it's going to go off or can it be put on a arming switch so it only goes off when armed and hits the right rpm?
04 mustang gt
7.21 @ 98
yep you'll have an arming switch...plus you gotta open the bottle
2004 mustang GT
Ok thank you for answering all of my questions.
#9 | |
4V swapped '02 GT
(2v) 13.9@101
ZEX? Traction Control Window Switch
1999 GT 35th LE
Just an FYI I think I spent about $1100 for everything I purchased for my nitrous setup.
You also will want a fuel pressure safety switch to turn the system off if your fuel pressure drops below 38 psi, or you can spend another $800 and get a stand alone fuel system. I think you need to spend some serious time researching some of the sticky posts on nitrous. The push button arming switch is not a good idea, lots of engines blown up using the push button. There are several progressive controllers available for use with nitrous. It all depends on how safe you want it to be and how much you want to spend.
![]() Drive it like you stole it |
Hsw microedge ftw
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Threads Similar to: Nitrous
| I am considering nitrous, so nitrous guys get in here!!! | zinsavage123 | 99-04 | 67 | December 1st, 2011 10:40 PM |
| Nitrous guys, help. Nitrous cams? | codycat91 | 99-04 | 10 | May 10th, 2011 06:00 AM |
| What to do with the nitrous switch after selling the nitrous? | maxgst | The Clubhouse | 19 | April 21st, 2011 11:32 PM |
| Getting Nitrous and new clutch installed...have a question about nitrous | VanWilder | 2005 - 2010 | 2 | May 13th, 2010 11:52 AM |
