2001 Mustang GT
TBD
Best time for tune???
I will be returning from Afghanistan in DEC, and was just wondering if it is a good idea to get a tune during this time frame??? I live in KY, so it will be cold as S#$t, I plan on moving to Florida sometime and was wondering if a winter tune will be a problem in a Flordia summer????
01 GT with 2.1 Kenne Bell, MMR 600 Aluminum Block, 4:10's, Dyno done 2/27/2012: 404RWHP
2001 Mustang GT
TBD
Bump, sorry
I like boobs!!!
2000 GT convertible
dunno
What do you have done to your car? Why do you think you need a tune?
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
If the tuner is good and its done right it wont matter. Your car will put down some impressive numbers in the cold though which is always fun.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
2001 Mustang GT
TBD
Kenne Bell 2.1, new MMR 600, adding 10 psi pulley, new JLT intake, with 75mm TB
2001 Mustang GT
TBD
Just found out my own answer, called the tuner and they run there shop at 70F and the Florida heat should not be a factor, thanks for the replies!!!
I like boobs!!!
2000 GT convertible
dunno
Well if you're doing all of that you will definately need a tune before you drive to Florida. The car isn't going to run right at all until you get that done. As Nightmare said, if they tuner is good, it won't make a bit of difference when you get the tune done. That's what the computer is there for, to compensate for different atmospheric conditions.
2001 Mustang GT
TBD
My car is done and running, KB sends a chip with the 2.1 that has been good for the last 2 years of me driving on it, yes I know I need a real tune, I will be installing the intake, TB and new pulley at the tune.
Threads Similar to: Best time for tune???
| Just loaded SCT 93 tune for the first time | JCCNY | 99-04 | 10 | March 30th, 2011 03:10 AM |
| Tune Time | svt95gt | 2005 - 2010 | 8 | February 21st, 2009 07:26 PM |
| tune up time | 03BMstang | 99-04 | 4 | June 22nd, 2008 02:57 PM |
| time for a tune up, little help? | B0B | 99-04 | 9 | January 24th, 2008 03:35 PM |
| When Is It Time For An N/A Tune? | 2000stangGT | 99-04 | 2 | September 22nd, 2006 12:26 PM |
