5k budget ideas pls !!! - Page 2
Old October 11th, 2011, 08:30 AM   #21
86er's Avatar
Originally Posted by zinsavage123 View Post
I doubt 5k will do a 4v swap unless your doing the work
really? Only real expense is the engine itself. Maybe a hose or two, but you can reuse the cops if you grind the bolt hole off, invert the wires, extend a few sensors.
Aviator engines go from 1200-1700 depending on the milage and salvage yard. Online is going to be your best bet.
Try Car-Part.com--Used Auto Parts Market or LKQ's web page
Just a truck
Old October 11th, 2011, 09:16 AM   #22
black02pony's Avatar
2002 mustang gt
12.6 @ 25mph
black02pony is on a distinguished road
there s a kenne bell 1.7 on ebay.
FoMoCo " The Best Never Rest "
Old October 11th, 2011, 09:42 AM   #23
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
I'm going to have to agree with a few others and say $5k isn't enough to do a quality swap. You will need the harness, engine, cams, intake, fuel system, then you'll need someone to tune it so it runs right. There's just a lot to do and unfortunately $5k runs out reeeeeally fast when you have a Ford. FORD = Forking Over Riches Daily
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old October 11th, 2011, 11:42 AM   #24
2001 mustang gt
GtUnit is on a distinguished road
The reason i want a 4v is beacuse it has better air flow than 2v
There is more potential in a 4v
Im trying to get a high hp motor thats n/a then i would add a blower and maby some funny gas
I know i could get a 4v engine with built block for 4k
Old October 11th, 2011, 03:17 PM   #25
Kevin C's Avatar
2001 Mustang GT
34.82 @ 21
Kevin C will become famous soon enoughKevin C will become famous soon enough
You're full of knowledge 86er. Now I'm going to be browsing that site for a while.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates
Vortech V1 sold
Old October 11th, 2011, 06:35 PM   #26
86er's Avatar
wrong wrong wrong wrong wrong wrong wrong.
an aviator has the same cams as the mach, maurader, and cobra of 03/04. the heads are the same. yes the guts suck, but to just get an engine in and going its a great bet.
You dont need the harness, you dont need the pcm. You can modify the 2v harness, which is extending and inverting the cop wires, extending the iac/tps and thats it. The fuel rail will work, its returnless, you drop a 4v tune into the pcm and go about your merry way.
engine 2k, tune 500, a few extras etc 500, your at 3k. you can put some cams, and long tubes and rock a 370hp motor, swap to a mach/cobra intake and get closer to 400 and have a hell of a fun ride
Just a truck
Old October 11th, 2011, 07:44 PM   #27
Kevin C's Avatar
2001 Mustang GT
34.82 @ 21
I need to one day find a super cheap 99-04 GT roller and let you go to work on it. As much power as possible for 4-5K, lol.
Vortech V1 sold
Old October 11th, 2011, 09:11 PM   #28
2001 mustang gt
By any chance does the aviator head have any tick problems like the cobra heads???
Old October 11th, 2011, 11:07 PM   #29
86er's Avatar
No idea, but if the engine is out, do the coolant mod and bam, its fixed
Just a truck
Old October 11th, 2011, 11:23 PM   #30
2001 mustang gt
Well ill look around for a good price for an aviator engine forge it buy long tubes and add a mach 1 or cobra intake if i have enough ill buy a good set of cams ( any recomandations)
Old October 12th, 2011, 12:04 AM   #31
86er's Avatar
cams are the last piece of the puzzle, when you have all your other pieces, you pick out your cams to tie them all together. MHS has good ones, comps got a few good grinds also
Just a truck
Old October 12th, 2011, 12:06 AM   #32
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
Originally Posted by Kevin C View Post
Hell, somehow my N/A GT has enough grunt in it to consistently chirp 3rd and 4th gear, and while I have my Vortech sitting in the house, I'm perfectly happy with it now.
It's called crappy tires
Vortech V2 Si
Old October 12th, 2011, 12:46 AM   #33
86er's Avatar
get it to memphis and youre on
Just a truck
Threads Similar to: 5k budget ideas pls !!!
s/c on a budget 04gtvert 99-04 35 August 31st, 2011 12:21 AM
Budget build Huggy General Tech 1 June 6th, 2011 02:44 PM
$7k budget what to do for my V6? focus0frenzy1 V6 Mustangs 76 March 30th, 2011 02:49 PM
budget 5.0l build, how am i doing? 8*5.0LX*7 5.0 Mustangs 53 February 1st, 2010 04:28 PM
