2004 mustang gt
12.66@89.67
New cams!!! And heads any suggestions
im thinking of getting my 04 mustang gt cammed but i need suggestions i got the regualr bolt on magnaflow magnapack exhaust and x pipe, accel coil packs, k&n cold air intake, proffesional products throttle body and plenum, steeda underdrive pullies i got the sct 4 bank eliminator chip wich would probably have to come of i got 3.73 gears im looking to get cams is it better just to port my heads or get performance ones and does any one know any good packages and everything i need for a cams swap thanx
If its a street car stick with stage 1 cams of some sort. Stage 2 cams will make more PEAK HP but a stage 1 cam setup will make more power under the curve and be quicker stop light to stop light. Most people get cams for sound anyways though (which couldnt be more wrong)
Check out modularheadshop.com They have some great packages and some good camshaft selections
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Tfs makes a compleat heads cam and valtrain package but im not sure how good their cams are. But their heads are nice. I don't really sugest putting those heads on a stock rotator.
![]() bone stock from the factory! |
I like boobs!!!
2000 GT convertible
dunno
What's your budget? Trick Flows are the only true aftermarket performance castings for the modular engines. Everyone else just ports out stock castings and calls them performance. You can see that in the price too. That's why you're going to pay more for Trick Flows, but IMO they are worth it.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
For you standard bolt on car with a stage 1 or 2 cam - ported stockers work great. The trick flow may put up a little better peak hp numbers but the stock ported heads will make more power under the curve.
All Motor 1998 GT
The TFS heads are great but not required. A good set of ported PI heads and smallish aftermarket cams will make great power. You can get the TFS stuff as a package but I sure Nick at Modular Head Shop can put something together for you as well.
Threads Similar to: New cams!!! And heads any suggestions
| Cam suggestions with GT40 heads/intake. | timalev | 5.0 Mustangs | 25 | October 18th, 2010 10:22 AM |
| Cams Suggestions. | Ugmul | 99-04 | 30 | March 21st, 2009 02:31 PM |
| comp. or vt cams? and other suggestions | SWEET2KSTANG | 99-04 | 0 | February 24th, 2007 10:10 AM |
| Need suggestions on aftermarket heads | 1StockGT | 99-04 | 4 | December 30th, 2006 05:46 PM |
