would 3.27's cause turbo lag?
Old October 11th, 2011, 01:48 AM   #1
JoshDrex00gt's Avatar
JoshDrex00gt will become famous soon enough
hey guys, been debating my gear situation lately. have 3.73's on my 00 auto, and i'm running about 115 ish at end of 4th. would like this to be a little higher, and wasn't sure if 3.55's will be a lot better. thinking of kicking it down to the stock gears especially when I'l be running higher boost soon. I just wasn't sure if this would create too much turbo lag. I'd appreciate any help.
thanks joshua
ll 2000 Mustang GT : On3 Powered ll
Old October 11th, 2011, 01:50 AM   #2
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
I say 3.27's. Itll help spool the turbo quicker. Especially at your power level, 3.27s will be nasty. That thing will pull like a freight train to 140mph
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old October 11th, 2011, 01:53 AM   #3
86er's Avatar
Id pick up a convertor also if you dont have one, to go along with the 3.27's. The gears dont produce lag so to speak. The higher gearing will take a smidge more to get moving, but the torque should help walk all over that gearing, plus a convertor is just a bonus to help get into the power band and let the higher gearing help spool the turbos longer and pull harder as stated
Just a truck
Old October 11th, 2011, 02:01 AM   #4
thanks Shaun and 86er, exactly what I needed to know. I had originally wanted 3.55's but the shop got the wrong one's and I went with the 3.73's he had in stock versus keeping my 4.10's. he said if I wasn't happy with them, he would change them out at no charge whenever. so I'm thinking of doing that when i go back with the toyo's for retune and more boost d[-_-]b
Old October 11th, 2011, 02:12 AM   #5
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
stock gears suck even with f/i
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old October 11th, 2011, 03:47 AM   #6
@GTRags: why you say that bro?
Old October 11th, 2011, 04:21 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Depending on your goals a little more gear will help track times with a turbo, bit turbos spool fastest with a continuous load which being an auto really helps. Getting a converter and some sticky tires will really helps getting more power out of the hole
bone stock from the factory!
Old October 11th, 2011, 04:49 AM   #8
no track duties yet fellas, waiting til after college to get into that sort of wear and tear on my car.
Old October 11th, 2011, 08:32 AM   #9
86er's Avatar
Originally Posted by G.T. Rags View Post
3.55.....
yeah that hole .28 in gearing is HUGE these ratios. On a semi stock turbo car, you wont see much difference with the two.
Just a truck
Old October 11th, 2011, 09:22 AM   #10
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
The difference between 3.55s and 3.27s is 8.6%. The difference between 4.10s and 3.73s is 9.9%. Maybe the difference isn't much but there is a huge 4.10/3.73 debate. By the way, the difference between 3.73s and 3.55s is only 5.1%.
I understand why you might want to go to a higher gear on the street. It gives you a higher top end in third. If you're stopping at redline (115 with 3.73s) then your top speed would be 121 with 3.55s and 131 with 3.27s. You can only get to 140 by pushing it into the red.
But I don't understand how this would be beneficial on the strip. With a trap speed of 115 mph, with 3.73s your rpms are around 5788 (readline), 3.55s they would be 5506, and with 3.27s they would be 5073. Turbos are supposed to reach max boost at 3500 but max horsepower would still be around 5800-5900 rpms. It seems to me that crossing the line at 5100 rpms leaves a lot on the table.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old October 11th, 2011, 11:58 AM   #11
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Keep the 373s and get in a 28in tall tire IMO. The 373s will be good for track use and the 355 for street. The 327s all good with non od transmissions like the c4 or th400
Old October 11th, 2011, 01:29 PM   #12
idk if it matters some said semi-stock car. it'll be pushing 16-18 psi and idk the horespower hoping for 600. to all the track talk, i'll have most likely less than 5 trips in next two years. when i finish college i'll be putting 3.55-3.73's back in and going into building it for track purposes. as for now I drive it daily to school and work without a second car if this one goes down.
Old October 11th, 2011, 01:30 PM   #13
guarnibl is on a distinguished road
3.55.....
3.73's w/ viper spec.
Otherwise 3.55's.
2003 Mustang GT - Dark Shadow Gray
302 2v stroker motor
Stage III VT Supercharger cams
Stage II P&P Patriot Heads w/ custom valve job.
Dual Ford GT40 pumps, cobra tank, 8an lines, billet fuel rails, dual fpdm w/ upgraded wiring, FORE fuel hat.
Old October 11th, 2011, 02:19 PM   #14
BYAHHHH!
2001 Mustang GT
13.874
I'd put 355 in it now and call it good
Old October 11th, 2011, 06:10 PM   #15
Scott what's the speed at top of 4th in an auto with 3.55's. shifting at say 6k to make it simple?
Old October 11th, 2011, 07:11 PM   #16
stal94gt's Avatar
2003 mustang v6 ;)
slow
I would not be counting on 4th as a track gear, you want to stay in 3rd when you get threw the traps
Old October 11th, 2011, 07:25 PM   #17
BYAHHHH!
2001 Mustang GT
13.874
Not sure. I'll also have a 28 in tire in it
Old October 11th, 2011, 07:43 PM   #18
04MidnightGT's Avatar
12.9 @ 111.44
04MidnightGT will become famous soon enough04MidnightGT will become famous soon enough
Hmm I always get extremely close to topping out 3rd in the 1/4 and my highest trap speed has been like 98mph... I feel like I'm doing something wrong
Stock 3.55's w/ 5spd...
l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow
Old October 11th, 2011, 07:55 PM   #19
BYAHHHH!
2001 Mustang GT
13.874
He is saying in an auto. Not 5 speed
Old October 11th, 2011, 08:07 PM   #20
I did not know that man, good to know. will help im my decision making
