Procharger Install Prep
Old October 11th, 2011, 10:40 AM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
Hi all,
So I took my Mustang to Evolution Auto Care for them to make sure I have everything I needed for my Procharger install on my 01 GT Convertible.
They said the blower looked pretty good, and I have everything I needed for them to put it on; however, they suggested I replace the Harmonic Balancer since mine was showing a lil wear on the rubber.
I did a little research and the Powerbond SFI seems like a good brand, but am unsure as to what size I need.
Old October 11th, 2011, 11:03 AM   #2
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
According to Innovators West the stock size is 6.5".
For reference: A 10% overdrive pulley is 7.25" and a 15% overdrive pulley is 7.5". A 10% underdrive pulley is 5.875".
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old October 11th, 2011, 01:22 PM   #3
What should I expect to spend on a new one? I take it there's no way to replace just the rubber?
Old October 11th, 2011, 03:03 PM   #4
12.73@111.36
I had to replace my crank pulley because the previous owner had installed underdrive pulleys. I think I paid $250 at a dealership. What are your plans? How much boost are you planning on running this year? Do you intend to add more boost later? If so it might be better to get the $440 Innovative West 10% overdrive crank pulley. It allows you to generate more boost with larger supercharger pulleys. But if you're running a stock motor it might be too much right now.
For example, a P1SC generates approximately 12 psi witn a 3.4" pulley and a stock crank. You can get the same thing with a 3.85" pulley (normally an 8 psi pulley) and a 10% overdrive crank pulley. Both spin the blower at 46,000 rpms at 6000 engine rpms. (P1SC max blower rpms is 62,000.) There is a lot less risk of belt slippage with a 3.85" pulley.
Old October 11th, 2011, 03:29 PM   #5
Old October 11th, 2011, 03:36 PM   #6
The pulley has to be a 3.60, I'm guessing 6-8psi? I don't really want to go crazy on a stock block and I don't have any plans to upgrade the internals, but I do have the 42 injectors and high flow pump just in case I change my mind.
Old October 11th, 2011, 03:41 PM   #7
12.73@111.36
If your P1SC pulley is 3.6" then you will most likely be making around 10 psi. I'm making 9 psi with a 3.7" pulley. You would not want to run that supercharger pulley on a stock motor with an overdrive pulley.
Old October 11th, 2011, 03:56 PM   #8
My bad, it's the 3.85, i just went out there with a ruler...
Old October 11th, 2011, 04:01 PM   #9
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Just going to throw this out there-
If you step up to a larger crank pulley, you may want a larger alternator pulley. Some people go with a much larger crank pulley w/o changing the alternator, and then wonder why they're frying alternators left and right.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old October 11th, 2011, 04:08 PM   #10
I do run a system in the car... got a capaciter for 2 10's and 4/2 chan amps for all door speakers... there's still prob a large draw on the alternator
Think I should stick with the stock size pulley?
Old October 11th, 2011, 04:40 PM   #11
MM's king of Neon's
404 - car not found
17.81@87
It not so much about the draw as the physical constraints of the alternator itself. Much like your engine there's a certain RPM limit before damage starts occuring.
If you are inclined to keep it at the factory RPM, make sure the ratio of your crank pulley to alternator pulley stays the same.
Ex; stock is 4" crank, 2" alternator, and you go to a 6" crank. You'll want a 3" alternator pulley to compensate for the size change.
Old October 11th, 2011, 04:44 PM   #12
Keep it at the same ratio, got it... are they 2:1 or was that just you using that as an example?
Old October 11th, 2011, 09:38 PM   #13
12.73@111.36
That was just an example the crank pulley is 6.5". I don't know what the altenator pulley is.
Old October 11th, 2011, 09:45 PM   #14
MM's king of Neon's
404 - car not found
17.81@87
You've got to do all the mathematizing yourself.
Threads Similar to: Procharger Install Prep
03 gt procharger install Petty886596 99-04 0 May 7th, 2011 10:33 PM
Procharger Install Help Runriot 99-04 119 May 9th, 2010 12:34 AM
Procharger INSTALL!! Scott2001GT 99-04 109 March 3rd, 2010 08:44 PM
Procharger Install 95% gsjohnson 99-04 40 December 4th, 2007 06:11 PM
Procharger Install 2001Mustang Saleen 99-04 17 October 6th, 2007 03:27 AM
