2003 Sonic Blue GT
![]() iTrader: 1 reviews
O2 Sensor HELP
OK so here's the deal. I installed some new longtubes on the car, (pacesetters, they are HORRIBLE, dont buy em, its to late for me though.) And the o2 sensor bung on the driver side header is pointed right at the spring on the transmission that changes gears(i have an automatic, not sure of the name of that part)
So, basically i cant plug in my front 2 o2 sensors. It is causing me to get HORRIBLE gas mileage, so i was wondering if i could lengthen the front o2 wires long enough to reach the 2 rear 02 bungs, i know the reading then wouldnt be as accurate, but at least it would be reading something? |
12.9 @ 111.44
I don't see why making the wires longer would affect anything lol, what are you doing for the mean time just have the O2 bung plugged? If your car is running like ass and you can't wait to buy a part to extend it go buy the appropriate size wire and lengthen the wires yourself, make it clean with some heat shrink. I've done it on a friends car and it worked fine.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2003 Sonic Blue GT
I wasnt worried about the length of the wires so much as compared to the position of the front o2 sensors. IE being in the rear o2 sensor bungs.
Yea, right now they are just unplugged, and running like ass is an understatement. Getting half my normal gas mileage. My plan is to get up early in the morning and extend the front o2 sensor wires so they will reach to where i can plug em in and see how it works. |
#4 | |
2003 Mustang Fauxbra
N/T @ Fast
The issue isn't with the wiring, it's with the placement of the O2 in the stream. Go to a muffler shop and have them weld in some new O2 bungs closer to the front where you won't have interference from the trans and then plug the old bungs. You'll still either need to extend the O2 wiring to reach the bungs on long tubes or buy extenders. This isn't the end of the world, it's simply a hill to climb. Easy fix.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
#6 | ||
MM's king of Neon's
404 - car not found
17.81@87
Unfortunately open loop isn't the most accurate. It's usually excessively rich, which means your fuel economy will plummet. Also if you have cats, prolonged rich mixture can cause overheating and failure.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2000 Mustang GT Super'ed
![]() iTrader: 2 reviews
If the sensors are placed in the rear ports, it's not the end of the world. But if that location is after any installed cat, then you have a problem...
![]() Saleen Series II 377whp/390wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Spec Stage 2, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, X2 Balljoints, Cobra Brakes, SS Lines. |
Threads Similar to: O2 Sensor HELP
| P0141 O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) | Shaun03GT | 99-04 | 23 | March 19th, 2011 12:08 AM |
| PF Sensor | yellowstang98 | 96-98 | 16 | February 17th, 2009 08:38 AM |
| map/bap sensor | R0B0T | 5.0 Mustangs | 1 | January 19th, 2009 04:29 PM |
| need sensor help | mikethetigerrr | 99-04 | 9 | September 6th, 2007 04:29 PM |
| Bad O2 sensor? | ltsmash1200 | 99-04 | 2 | May 17th, 2007 12:09 PM |
