Fuel Pump Wiring Grommets
Old October 11th, 2011, 09:57 PM   #1
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Since the dual FPDM wiring requires a second set of wires to the pumps, I have to figure out how to effectively seal the wiring for the secondary pump to prevent throwing EVAP codes.
I picked up a container of assorted grommets from Advance and I'm contemplating 2 options; two holes and grommets or running both of them through the same grommet/hole. Space to drill on the hat looks to be at a premium so I'm leaning towards the single hole option.
Has anyone done this before?
Or does everyone just say "to hell with it, delete EVAP in the tune"?
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old October 11th, 2011, 10:15 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
becarefull which gromet you use. it would suck to have it rot from the gas fumes.
bone stock from the factory!
Old October 11th, 2011, 10:19 PM   #3
MM's king of Neon's
404 - car not found
17.81@87
They appear to be some sort of vinyl.
Looking at the Fore hat it looks like they just run them all through one port. Not sure how that is for EVAP though, or if guys running that hat even care much.
EDIT:
Fuck it. Here's the solution I'm running with for anyone that goes down this route:
http://www.autozone.com/autozone/acc...Epoxy/_/N-259t
Explicitly fuel compatible epoxy for $5. That'll work.
Also for anyone interested, I'll be using a alternator harness extension from NAPA as a quick disconnect between the fuel tank hat and the chassis harness.
Old October 12th, 2011, 01:42 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i ran new 10ga wires from both my fpdm's to fuel pumps. i drilled holes just large enough for thegromet and wires to pass thru, and sealed them with epoxy inside. the top of the hat isnt really going to see much fuel except when its pretty full and sloshing around. even then, its going to be limited because of all the other stuff in the way.
Old October 12th, 2011, 08:21 AM   #5
Rabid Stang's Avatar
1999 Mustang TermiGT
Rabid Stang will become famous soon enough
This is the best option.
Fuel Hat wiring
Mods
545 RWHP/580 RWTQ on a Mustang Dyno
Delta Force Tuned by Team Pure Insanity Racing
Old October 12th, 2011, 08:27 AM   #6
MM's king of Neon's
404 - car not found
17.81@87
Fuel Hat wiring
That is precisely what I was looking for. Reps.
Now to hunt down all those washers.
Old October 12th, 2011, 10:46 AM   #7
Home Depot has them all.
Mods
Threads Similar to: Fuel Pump Wiring Grommets
fpdm/fuel pump wiring upgrade SWEET2KSTANG 99-04 49 May 3rd, 2012 07:46 PM
Cobra fuel pump wiring diagram? 04MidnightGT 99-04 18 September 10th, 2011 01:24 AM
wiring in a second fuel pump? ZoomZoomMFer The Clubhouse 23 April 30th, 2010 03:13 AM
Fuel Pump Wiring diagram mustangsusie V6 Mustangs 14 June 25th, 2008 05:22 PM
Fuel Pump Wiring Problem Black Five 0h 5.0 Mustangs 3 December 25th, 2007 12:32 AM
