LED gauge cluster and AC control light conversion was a SUCCESS!
I got curious about changing my dash lights so i got on eBay and bought 10 replacement LED bulbs for my gauges for $10 and put them in last night in about 10 mins and am very pleased. No more green gauges for me! Even tho they were some cheap $10 bulbs, they look great and arent overwhelmingly bright and ive got 5 extra bulbs just in case some go out.
lol well you're in a 2000 so you can do that..lucky bastard....most of us would have to get to sanding beforehand
Haha i apologize im not tryin to rub it in. And just curious.....wat would you have to sand on and in wat year model cars? im new to mustangs so ive been asking a bunch of seemingly dur dur dur questions to all of you vets.
99-00 (maybe '01 as well)...are easy for bulb changing for color choices...but in the late new edges (the model stang from 99-04) there is a green film behind the numbers on our cluster so the light is green at night...so to change color we have to sand the film off then replace the bulbs...it's a pita which is why i'm just adding reverse glow gauges
#5 | |
2003 Mustang GT
Why would you post this without pictures?
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
is the gauge cluster easy to take out? i have a 99 so if all i have to do is order some new bulbs then im doing it lol. the green is hideous.
pics!!!!!! |
99 Mustang GT 35th ed.
I have a 99 Gt as well, pics please! lol
Also can we please have the link to bulbs similar to the ones you purchased? Thanks
just go to superbrightleds.com...that's where i get mind from...the bulb is a 194
btw..the cluster is very easy to remove...don't remember the size torx bit you need but it's not an odd ball size |
Great thanks, I am looking at the site now, how many bulbs do I need for the gauge cluster and the a/c controls?
if i remember how many i pulled the last time i put reverseglows on my old stang it's 5 behind the cluster and 3 in the hvac...maybe order 10-12 just to have some spares
on my sixxer i'll be doing a reverse glow setup on the gauges but i will be doing my hvac in blue to match color wise at night |
Yeah I guess ill go ahead an order a good amount since they are cheap.
By the 194 did you mean bulbs like this one? Miniature Wedge Base Bulbs - Super Bright LEDs Sorry for my ignorance lol I'm just not too familiar with bulbs and want to make sure i purchase the right ones.
#13 | |
I had totally forgotten about those, thanks for the help man I appreciate it
Sorry i havent reposted. If you pull off the headlight knob switch there are 2 7mm bolts on the top part of the gauge bezel. its also got 4 clips that hold it in place. pull that off and then you have access to the cluster. There are 4 7mm bolts in each corner of the cluster. Take them out and you can pull out the cluster. There will be two wire plugs on the back of it. Unplug them 2 plugs and you can take the cluster out. Once you have it out u will need a pair of needle nose pliers to pull the bulbs out the cluster.you will see 5 white caps for bulbs goin in a slight curve across the back of the cluster. Use the needle nose pliers to turn turn the caps light you were unlocking a blinker bulb plug. Them out one by one or all at once and you may have to wiggles the bulbs out cause mine were stuck from being in for so long. once u pull them out you can replace them with the led bulbs. replace them all and plug the cluster back up and test them. The LED bulbs have a positive and negative wire on them so that can get turned around. No harm to them they just wont come on. Pull that bulb out the socket and flip it around and thatll fix your problem. and them you bolt her all back together and you have a LED conversion. And im new to this forum so idk how to upload pics of i would :/ and i will get the link to the place i bought mine off of. I looked on superbrightleds.com and they are exactly as the website says. super bright. I personally dont like it. too bright for night riding. mine arent stupid bright but bright enough that i can clearly see my gauges and plus i dont have to look at that ugly green lol
also too the bulbs behind the AC control are different than the once behind the cluster. They are a little bigger. I can try and get the bulb sizes for everyone wantin to do this as well. Sorry guys im a newb
Here is the link to bulbs on ebay that i got for my gauge cluster:
If someone will tell me how to upload pics i will gladly add them on here. I dont even kno how to set myself an avatar! Ugh
Threads Similar to: LED gauge cluster and AC control light conversion was a SUCCESS!
| gauge cluster light problems. need help please! | 02trueblueGT | 99-04 | 1 | June 20th, 2011 10:36 PM |
| Red or Blue Cluster/HVAC/Radio Conversion..CCD | Archy88 | Visual | 14 | May 4th, 2009 02:29 AM |
| gauge cluster light | blazor | V6 Mustangs | 6 | July 10th, 2007 09:01 PM |
| swapping '95 V6 gauge cluster to a '94-'98 GT cluster? | Alocatelli | V6 Mustangs | 3 | April 4th, 2007 02:38 PM |
| new gauge cluster install problems plz help theft light | bigpopaz99 | V6 Mustangs | 22 | December 15th, 2006 02:29 AM |
