Rims and bolt pattern?
Old May 25th, 2007, 07:32 PM   #1
MySallyMI is on a distinguished road
Will rims interchange between an 03 gt and an 07 GT? Or is the bolt pattern different?
Old May 25th, 2007, 07:38 PM   #2
energiesource's Avatar
energiesource is on a distinguished road
the bolt pattern is the same, but the offset is different, so they wont fit
Old May 25th, 2007, 07:40 PM   #3
ok thanks for the quick answer, but what does the offset mean? Im not familiar with that term.
Old May 25th, 2007, 07:43 PM   #4
Offset is, simply, the distance between the face of a vehicle wheel which mates with the hub and the true centreline of the wheel. Offset can be positive, negative or zero. It is important because it affects the scrub radius of the steering system, the clearance between the tire and the suspension and the load on suspension components.
Old May 25th, 2007, 07:47 PM   #5
this makes it easier
Old May 25th, 2007, 09:13 PM   #6
maddymac07 is on a distinguished road
tecnically they will fit but the 07 wheels will stick in too far on the 02 but the will bolt on but look stupid
Threads Similar to: Rims and bolt pattern?
Bolt pattern mustangmanic 99-04 8 October 10th, 2007 08:57 PM
bolt pattern theodoor24 Classic Mustangs 4 May 8th, 2007 02:15 PM
what is my 4 bolt pattern? YNOT 5.0 Mustangs 8 March 25th, 2007 02:12 AM
96 rim bolt pattern? Ninjawafers! V6 Mustangs 3 December 30th, 2006 12:02 AM
Bolt Pattern DILO2001GT 99-04 2 October 3rd, 2006 01:44 PM
