Block identification
Old May 26th, 2007, 04:43 PM   #1
hubba076's Avatar
hubba076 is on a distinguished road
Does anybody know how to find what block is in a 2003 Mustang Gt?? I have heard that there were two different blocks used---Windsor and Romeo...How can you find out for sure (vin or block itself) and what is the difference between the two blocks???
2003 Mustang GT. Red HOT Bitch! Many mods to come...
Old May 26th, 2007, 05:01 PM   #2
2000 Mustang Gt
13.56 @ 106
2000stangGT is on a distinguished road
in an 03 it should be romeo, but check the number of bolts on the head, i think its 13 romeo 11 windsor
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
Old May 27th, 2007, 12:02 AM   #3
hubba076's Avatar
Yeah...I thought I heard something like that before. Do you have to take off the valve covers to find out or is it the same number of bolts that connects the cover to the head??
Any info why Ford used two different blocks and which is better??? Any differece at all???
Old May 27th, 2007, 03:45 AM   #4
1999 Mustang
Invictus is on a distinguished road
same number of bolts on the valve cover as well. just pop the hood and count em
11bolt = romeo
13bolt = windsor
only differences i know of is that the romeo's have bolt on cam gears which makes the cam swap a little more pleasant and save you about $80.00 for a bolt on cam gear kit (if you're doing the swap)
and the romeo heads use cam girdles instead of cam caps on the camshafts
other than the cam swap being a bit eaiser with the romeo motor, the performance numbers are identical
thats all i know, just from experience. hope it helps
Threads Similar to: Block identification
Boss block or Dart block??? JONJON 5.0 Mustangs 48 November 6th, 2007 10:37 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 11:57 PM
Lifter tick identification wanabebuff 5.0 Mustangs 15 June 12th, 2007 08:02 PM
351 W head identification 351confused The Clubhouse 3 February 12th, 2007 07:05 AM
Engine IDentification Cskit1500 5.0 Mustangs 2 December 4th, 2006 02:06 AM
