Question Regarding Shortblocks for 99-00 Gt's
Old May 26th, 2007, 09:29 PM   #1
Bigb2000GT's Avatar
Bigb2000GT is on a distinguished road
I understand that 99-00 GT's use a 8 bolt crankshaft / flywheel and clutch for the t-45 tranny so to my undersanding you cannot use a 01-04 engine because it will not bolt up without using a 3650 tranny clutch and flywheel is this correct? Shopping for shortblock and this dilema just popped into my head. also I understand that 03-04 cobras use a 8 bolt crankshaft/flywheel is it possible for that shortblock to bolt into a GT? I figure thats a heck no since they are designed for 4v heads.
RIDE:
2000GT- MODS: 2007 3 VALVE ENGINE AND MORE......
Old May 26th, 2007, 09:35 PM   #2
Proud American
MustangMatt96GT's Avatar
Well my 96 has a T-45 and 6 bolts on the flywheel!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 26th, 2007, 09:47 PM   #3
Bigb2000GT's Avatar
yeah to my knowledge it was a 6 bolt crankshaft/flywheel for 96-98 and mid 01-04 the 99-early 01 use 8 bolt crankshaft/flywheel which got me thinking cause most places ive looked that sale built shortblocks only advertise ones with a 6 bolt crankshaft which got me thinking that It may require me getting a new tranny to get a built block or maybe all I need is a 6 bolt flywheel and clutch to make it work? I dont know I may be over reacting Im sure they gotta make built shortblocks that will bolt into the 99-early 01s but it just kinda freaked me out. Im not a real know it all when it comes to engines but im an expert at changing oil, air filter and spark plugs just from what im reading it looks as if those engines will not bolt up to my combo.
RIDE:
Old May 26th, 2007, 10:25 PM   #4
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
You can buy a flywheel that will make everything compatible- you shouldn't have any concerns. Call Spec in AL if you won't to make for sure.
Old May 27th, 2007, 11:42 AM   #5
Bigb2000GT's Avatar
Thats what I figured but another concern of mine would be the heads Im gonna need to get 02-04 heads correct or would both the romero and windsor bolt to a windsor block?
RIDE:
Old May 27th, 2007, 02:18 PM   #6
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
both romeo and windsor heads will bolt up, the only difference is the valve covers, and yes all you would have to do is change your flywheel and your clutch and tranny will bolt right to it.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Threads Similar to: Question Regarding Shortblocks for 99-00 Gt's
'00 GT's actin a fool again MSTGGT00 99-04 11 November 8th, 2007 04:29 PM
99-04 vs 05+ GT's MacGill 2005 - 2010 21 October 13th, 2007 02:48 PM
Forged shortblocks.. whtpny 99-04 5 August 7th, 2007 07:42 AM
Pre 99 Gt's ESG-642T V6 Mustangs 11 March 20th, 2007 02:13 PM
My GT ate a Celica GT's Face thewayshemoves 99-04 7 December 3rd, 2006 02:21 AM
