03 gt
Help w/ NA cams
Ok so over the winter im buying a set of cams but dont know what to look for.
As it sits now: BBK shorties Catted x Slp lm1's CAI BBK tb I want a set of NA cams that will go with my mods and 4.10's can some one please help. |
04 mustang GT
slow
cms stage 2 cams are nice,set of comp valve springs and retainers.
#3 | |
Disturbin' The Peace
2003 Mustang GT
![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Comp 262's
CMS stage 1 Hitech stage 1 All are good options for a bolt on car. Stage 2 cams are more likely to cause PTV and you would need to wind your engine to around 7k to get the full benefit from them. Stock 2v bottom end should not rev that high.
![]() 2003 Mustang GT STD 259rwhp 298rwtq
04 mustang GT
slow
ya thats true
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
I'd have to say CMS stage 2. Apparently they're some of the only "stage 2" cams you can safely run on a completely stock PI 4.6. Even HiTech stage 2s cause PTV issues, which was interesting for me to learn since I used to want them. Not much, but enough to leave some scuffs on your pistons.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
03 gt
Where can i get cms cams?
00 mustang gt
Cushman motor sports... Cms stage 2 is what I got and love them.. I sent them to MHs and had them degreed and have had no issues with them.. And I get complments all the time on how mean it sounds
![]() Cms stage 2 cams 04 explorer aluminum engine spec 3 clutch sct x3 k and n cai 410 gears underdrive pulleys roush short throw |
![]() iTrader: 3 reviews
Personally I would stick with a stage 1 cam, you're not going to get the full potential of stage 2 cams with stock pistons, more likely to have ptv issues and its roughly a 5 hp difference between stage 1 and 2s. Read allover the forum guys have to really retard the timing on the stage 2 cams just to avoid ptv. Cms stage 1 or comp stage 1 and you'll be golden.
00 mustang gt
Why buy stage 1 when stage 2 cost the same? And ptv issues are avoided if the cams are installed right..
But you still have to retard the timing quite a bit to avoid it and stock internals can't even rev that high to utilize the stage 2. I'm not saying there's anything wrong with stage 2s but if I had a stock rotating assembly personally I would go with the 1s.
I like boobs!!!
2000 GT convertible
dunno
Or you could get the Trick Flow heads which have the piston placement moved to avoid PTV issues altogether. PTV, along with other factors, killed my engine. It was very apparent when I tore it down. I then talked to a friend of mine who has a lot of experience with the 4.6's and he told me that he's seen PTV contact on EVERY 4.6 he's ever torn down, even completely stock ones.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
03 gt
At what point will i need springs? and i cant afford the tf heads i would love to have them but they are not in my budget.
#13 | |
2003 Mustang GT
Springs are good when installing any cams, but not required until going with cams that have over .550 lift. Usually any brand "stage 2" cam requires them, except hitech ones, but if you were to do those and not do springs you couldn't rev the car over 6300 rpm.
04 GT
Here's a link. Read up. The real deal on the PTV stuff on these cams is right in the description.
You should concider MHS stage 2 IMHO ModularHeadShop Bullet Cams |
03 gt
How much rwhp will mhs stage 2's give me?
04 mustang gt
7.21 @ 98
around 270. give or take a few. possibly 280
![]() cams + 150 shot |
2001 Mustang GT
OMG! This thread is so full of bad information I wouldn't know where to start!
tuned by SPEEDY DYNO 12.41 @ 109 mph w/ CMS stage II cams 11.13 @ 122 mph NX 150 shot ![]() Launch soft, shift slow, rev low, stay slow
#18 | |
I've heard from JayC that his CMS stage 2 cams lost nothing down low. Those are a proven solid camshaft. I went CMS stage 2 blower cams for my new motor also. I have worked with Nick at MHS on several different things and have spent alot of money there but I prefer to purchase cams from Jim (CMS). He gives us a forum discount also which makes them hard to turn down.... Thats not to say there is a damn thing wrong with Nicks cams because there isnt. His grinds just didnt fit my goals for power, smog, driveability.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
i will say one thing i know for sure.... TUNING
So many cams swap HP figures, loss of bottom end, gain... everything you name it are all DIRECTLY related to the tune on the vehicle before and after. If your tuner doesnt work all of the timing table to get that great part throttle tq and hp your going to think its a dog down low. I spend as much time working the part throttle timing section of the spark borderline and MBT tables on my cars as I do on WOT timing. Its where all of your throttle response, part throttle power, acceleration and fuel economy come from.
Feel free to correct me...... If you have to retard the timing aren't you hurting the full potential of the cam? that's just my thought process I guess. Also from what I've read whp wise there's a minimal difference between 1 and 2 but how the power is distributed in the rpm range is what's different. Also are there any known issues with passing strictly OBD II emissions testing with stage 2 cam? I apologize in advance if I gave out bad info OP
Threads Similar to: Help w/ NA cams
| changing mach1 intake cams with 96-01 cobra cams?? | blue03mach1 | 4V / SVT | 19 | November 11th, 2009 02:11 PM |
| lunati cams vs. houston perf. vs. comp cams | mylilboostedpony | 99-04 | 0 | September 12th, 2009 06:05 PM |
| cams cams cams help me pick some cams | tlazyhpony | 2005 - 2010 | 13 | September 4th, 2009 02:27 AM |
