Mis-aligned rear end
I took my car to a different shop (just because I was in the area) for an alignment and they do theirs the old fashion way. The shop I usually go to uses the laser guided machine. This old school shop was not able to align my car because my rear end was not sitting center.
Visibly, I can noticeably see that my right rear tire is more flush with the fender than the left side is. And now that I think about that, I noticed that I bottom out on my left side often when making right turns. but never really bottom out on the right side while making left turns. (If there is an uneven-ness in the road during the turn). Is this a control arm issue? |
![]() iTrader: 1 reviews
very common issue with SN95 mustangs. I think its caused because of the rear and the body twisting during high torque. Mine was like this and i had the rear axle unbolted and moved over so it was in the center again.
2002 4.6L 5spd w/bolt ons intercooled/Vortech V3 Si trim |
2001 Mustang GT Vert.
Keep in mind these are production vehicles. The rear end might not looked centered between the fenders, but those are body panels, not suspension pick-up points. What matters more is if the suspension is centered with respect to the torque box pick up points, especially if you center your front k-member off the torque boxes. The best way to tell if the rear end is centered under the chassis is to hang a plumbob off the same point of the bolts that bolt the RLCA's to the torque boxes and measure that point perpendicular to the inner or outer line of the tire/rim.
A PHB can be used to recenter the rear end if it is off.
Mods in garage |
I Hate Convertibles...
Check your control arm bushings. This is a common issue with mustangs. It is usually a bad bushing or twisted control arm. I had this issue and it was from the bushings in one of the lower control arms and i had also tweaked the control arm.
Sent from my DROID BIONIC using AutoGuide App
#5 | |
2003 gt
5.4 32v on the way
If it bothers you too much and you dont see a bad bushing you can center your axle with adjustable upper control arms or a panhard bar. If it doesn't bother you you can just let it go.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
Visibly it does bother me a little bit but a bigger concern of mine is bottoming out on those turns (not that I'm hitting the turns at that high of a speed).
If it is a bad bushing or a twisted control arm, what happens next to fix it? The shop did mention something about something wrong with the control arm. |
#8 | |
00 mustang gt
I had this problem a Month or two ago.. This is common among these cars.. Mine was about half an inch to the right.. I just Quit worrying about it
![]() Cms stage 2 cams 04 explorer aluminum engine spec 3 clutch sct x3 k and n cai 410 gears underdrive pulleys roush short throw |
I took it to a a shop to get it put on a lift and the left upper control arm was a little loose. The control arm wiggles in a direction that its probably not supposed to wiggle in.
So that would be more of a bushing right? |
2001 Gt
Correct. If you have the cash just buy a nice set of new ones and make this problem go away.
Abyssinian of AX
'02 Saleen
19.34@42.259
As others have mentioned, it is common for the rear-axle of a 4-link to be off-center. It may NOT be, relative to the frame, but probably is
This is RARELY an issue, so would look to some other possibilties as to why you have rubbing issues. If it is that bad and you want it fixed, the control arms you need would be dictated by the driving you do *here it comes pepes..... wait for it.... WAAAAAIIIIIIIIIT* What are the ULTIMATE goals for your ride? Jazzer
Jazzer and his famous line
Threads Similar to: Mis-aligned rear end
| Finally aligned.. | 2VSouth | 99-04 | 7 | August 24th, 2011 10:59 AM |
| just got car aligned, quick question | Matt86 | 99-04 | 8 | July 24th, 2011 10:13 AM |
| 1967 mustang 289 camshaft/lifters not aligned? | Lankloman | Classic Mustangs | 1 | July 24th, 2010 10:37 AM |
| Belts not aligned?? | Chuluota5.0 | 5.0 Mustangs | 2 | November 20th, 2009 11:14 PM |
| tips not aligned.... | dave07GT | General Tech | 2 | March 10th, 2007 05:35 PM |
