too much total timing for nitrous? i think so... - Page 2
Old November 5th, 2011, 02:16 AM   #21
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
I think mine is only like 19 on motor and 18* on spray, its pretty safe.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old November 5th, 2011, 02:35 AM   #22
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Normally i set them up on a 2v with 23-24 degrees max wot timing. 19-21 on the bottle.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 5th, 2011, 09:46 AM   #23
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
nitmare if I send you my n/a file can you modify it down some for n/a and then make a copy and turn the timing down more for spray?
with the commando can you actually modify your shift points? that's the biggest dislike I have about this thing. stock the car shifts around 5600, so i told the tuner to shift 200rpm later(5800) and it'd shift at over 6k. so i turned it down to 100rpm over stock and it'd shift at 55/5600. I was thinking of setting it up to shift at mph not rpm because i hate having to manually shift this thing.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old November 5th, 2011, 09:47 AM   #24
11.85@116
also, I remember hearing that too much timing can hurt you power wise, so would running 5+ degrees over what i should be at be hurting power?
Old November 5th, 2011, 10:07 AM   #25
Jackpot, fishypoopypants!
2003 GT
1@3,000,000.... or is it 3,000,000@1?
Cathedral has a spectacular aura aboutCathedral has a spectacular aura about
edit. nevermind.
yoink!
Slipped Moebius
mhm28x9
alt.alien.vampire.flonk.flonk.flonk
Old November 5th, 2011, 10:09 AM   #26
11.85@116
Originally Posted by Cathedral View Post
I'm no expert, but from a laymans perspective, wouldn't you always want your nitrous timing to be less than n/a? Since the nitrous burns much faster, you'd want your timing to be 19-20 on the juice. Go too high and you risk detonation. I'm not saying you're close to that point, but wouldn't you always want your timing for nitrous to be less than your n/a? Same with boost.
yes you're correct. and i thought my timing was lower. on my tuner it asks if it's n/a nitrous or boosted. i selected nitrous and a 125 shot assuming it would pull 5* out from what it would n/a. but i guess i was wrong.
Old November 5th, 2011, 10:28 AM   #27
2003 GT
Damn you managed to get my quote before I deleted it. I thought you had more timing for your nitrous and less on the na. Then I re-read your post and realized I was
However, you're reading your WOT timing at 60* IAT, without actually spraying. If you were spraying, your IAT would be lower, and your timing would advance.
Then again, if you have a wet system, that doesn't matter does it.
EDIT: this is just me being a layman. I don't have any actual experience in this, I'm just throwing out ideas so don't take my word for anything.
yoink!
Slipped Moebius
mhm28x9
Old November 5th, 2011, 10:37 AM   #28
11.85@116
it is a wet system, i dont know what kind of effects it would have on the iats personally.
Old November 5th, 2011, 10:46 AM   #29
ytngt has a spectacular aura aboutytngt has a spectacular aura about
It should have no effect on iats. That is because the injection point should be downstream of the iat/maf.
Old November 5th, 2011, 10:55 AM   #30
11.85@116
yeah it is downstream. that's why i was confused as to why spraying it would cool it down.
Old November 5th, 2011, 11:04 AM   #31
2003 GT
With a dry system, the nitrous is injected upstream of the maf, so the maf/iat counters for the colder/denser air and gives more fuel, as well as adjusts timing. With a wet system, the fuel is already mixed in and is downstream of the iat. All I meant was that if you had a dry system, and weren't spraying, your IAT wouldn't adjust and so it wouldn't retard your timing, so you would have the numbers you're looking at. I guess all the confusion could have been avoided had I just asked, "do you have a wet or dry sytem?" Sorry.
yoink!
Slipped Moebius
mhm28x9
Old November 5th, 2011, 11:20 AM   #32
Not completely true...
A (IMO properly designed) dry system is injected after the maf. The tune is setup to add your enrichment fuel several hundred rpm before the window switch and up.
Spraying nitrous directly into/on the maf is a very shady way of getting enrichment fuel, but some do it this way.
Old November 5th, 2011, 02:44 PM   #33
Pm sent
Old November 5th, 2011, 04:24 PM   #34
Running too much timing is bad for alot of reasons. Depending on the year of the mustang too it may or may not have knock sensors. If it does and you run too much timing the knock sensors take it all out and more which isnt productive. I sent you a PM also.
Send me the following info to my email.
Your stock PCM tune file, the N/A tune your running.
All of the mods your vehicle has done to it.
I will set you up with a good n/a tune and a nitrous tune. Its on the house.
Old November 6th, 2011, 12:02 PM   #35
11.85@116
i will deff be sending you those files once i get home later, and the help is greatly appreciated.
Old November 6th, 2011, 01:15 PM   #36
2003 GT
Parking brak
edit: damn, I am a retard. posted here when I meant to make a new thread. wow. feel free to neg rep me
yoink!
Slipped Moebius
mhm28x9
Old November 12th, 2011, 03:51 PM   #37
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Originally Posted by Nitmare67 View Post
Its the spark borderline table. There really is 50 degrees of spark advance under some of those load settings. Thats where your fuel economy comes from.
There is also an MBT table and depending on the ECU and vehicle it will or will not be used. Many vehicles use both tables and default to the lower spark advance between the two tables. In those cases you will usually find the ECU follows the MBT table under part throttle settings and the spark borderline table under WOT settings. You will also find on GM and some others borderline spark table, knock table and MBT table. The MBT table is also used for torque calculation to determine how close the engine is running to spark for peak torque
Yes I get that. But I have also noticed that when I upped my timing in the BKT that it doesn't increase at all until I increase my values in the MAST (Max allowed). Some cars use the MBT as the MAST, and I have to adjust that by using all 50s, hense making it useless, so I can run the timing I want on the vehicle, without having to worry about the MAST capping the spark off cause of a number rather than a IAT or ECT sensor reading like its supposed to work.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Threads Similar to: too much total timing for nitrous? i think so...
timing with nitrous. militarymustang V6 Mustangs 3 May 16th, 2011 07:53 PM
nitrous and timing travis00 94-95 5 April 22nd, 2010 03:20 PM
Nitrous and what should I set my timing at Steves LX General Tech 2 September 28th, 2007 06:51 PM
Nitrous Timing zerofx150 99-04 5 April 26th, 2007 10:11 PM
Timing Adjust For Nitrous ChrisJ General Tech 7 July 18th, 2006 09:25 PM
