too much total timing for nitrous? i think so...
Old November 4th, 2011, 09:11 PM   #1
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
So i was bored today, figured I'd go out and do some datalogs of my n/a tune and 125 tunes i have on my sniper special forces tuner.
well i the highest timing i saw on the n/a runs were 29* which i figured was ok. then put on the nitrous tune, went out and did a couple logs and the highest i saw was 28*!!! Now i was under the impression i should be more in the lower 20's on the nitrous tune. this really shocked me, is my n/a tune just lacking a bunch of timing? or is the nitrous tune really as unsafe as it seems.
also the iats for the n/a tune were 50* and the iats for the nitrous tune were 60* for what it's worth.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old November 4th, 2011, 09:22 PM   #2
laoutlaw01's Avatar
laoutlaw01 is on a distinguished road
I would think the iat temps should be lower spraying . Don't take my word for it though as I'm new to the fuel injected scene.all I've ever had was carb setups(ol school).
Old November 4th, 2011, 09:32 PM   #3
11.85@116
i wasn't spraying at all, just datalogging the tune itself. they were both n/a runs just one was on my nitrous tune.
Old November 4th, 2011, 09:43 PM   #4
laoutlaw01's Avatar
Oh ok, hmm beats me then ,I'm stumped. On a different note how do you like the sniper? ,I'm torn between getting it or the SCT pro racer package.
Old November 4th, 2011, 09:47 PM   #5
11.85@116
i would never buy another sniper. if i had to buy another tuner it'd be an sct from am with the bama tunes. this thing sucks especially for auto cars. when i try and set shift points on it the thing just shifts at totally different rpm's every time i'm in it. now with this issue too, deff go with sct man. I got this from my buddy for 50 bucks, too good of a deal for a tuner to pass up. but i wish i would have now.
Old November 4th, 2011, 09:54 PM   #6
laoutlaw01's Avatar
Damn,well I gotta get something because I'm almost ready to do more than the previous owner did and I don't wanta go thru the hastle of trying to get this diablo chip reflashed.
Old November 4th, 2011, 10:03 PM   #7
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Hmmm.... Im not sure. I thought with a 100 shot you need to back it off 1* 125 2* and 150 3*. Im not 100% sure, but I thought I read that somewhere.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old November 4th, 2011, 10:04 PM   #8
11.85@116
anyone know what stock timing is? that'd help a lot in figuring out what it should be but i cant find that anywhere.
Old November 4th, 2011, 10:20 PM   #9
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Delta Force tuning is awesome but the sniper package really looks like its alot more than it is. Before you spend a bunch of money to upgrade to SCT purchase the commando package you can upgrade for less than the cost of an SCT handheld. You will have the same FULL tuning software that every dyno tuner uses. Thats all I use to tune cars. It has all the features of SCT or any other. The only limitation at that point will be your knowledge and that will come with time. You will be able to get your timing exactly like you want it though.
Send me your current N/A tune and I will modifiy it for nitrous. You can just run that until you get a dyno tune.... that is if you want help.
BTW the reason your timing is probably so high is because of the IAT. The ECU adds timing when colder IATs are detected. I usually disable these functions on all power adder cars. I only use the timing modifiers for hotter IAT temps.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 4th, 2011, 10:27 PM   #10
Also stock timing - well what people usually reference as far as max timing.... Is 21 degrees. Thats the spark borderline limit. Those values are then modified by several other functions. Realistically 19 degrees would work great for a 125 kit and be very safe. I used to run 20 degrees and 11.5 AFR but 19 has a little more added safety. Are you running a wet or dry kit?
Old November 4th, 2011, 10:30 PM   #11
Factory Mustang GT spark borderline table.
Old November 4th, 2011, 11:09 PM   #12
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
ill straight trade you my sct x3 for your sniper. I intend on doing my own tuning for my 5.4 and planned on trying out the sniper.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old November 4th, 2011, 11:16 PM   #13
Wyatt's #1 Slut
B's04gt's Avatar
N/A
B's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to all
Damn Nitmare you know your shit
Mods: -Eibach Pro Kit - K&N - Tuned for 91 octane - visual shit-
i'm definitely confused by this. i feel like a little unwitting gay boy that's seen another boy's penis for the first time.
i love Uranus
Old November 4th, 2011, 11:17 PM   #14
You cant do your own tuning with sniper special forces (which is what he has) you need sniper (its actually called Delta Force) Commando eddition. Special forces is a little better than your normal hand held. It has a few other features like part throttle timing, pats over ride and stuff like that. You need a full version software like SCT professional or delta force/sniper - commando
Old November 4th, 2011, 11:20 PM   #15
2003 gt
5.4 32v on the way
I was under the impression that I could buy the software separately for half the price of the comparable sct software.
Old November 4th, 2011, 11:41 PM   #16
Which software? You can upgrade your special forces to commando for about 300 I believe. The full commando tuning package runs about 600 but that is comparable to SCT 1800 package. Its full all parameter access. Its the shit. You cant buy it used though or ever sell it. Its licensed to you only. The sniper special forces package can be sold no problem and used by anyone just like the guy above did. Check out rabbid stang on here. He is a delta force dealer. he will get you the best price.
I've used SCT and Delta Force. I prefer delta force and it has capability that SCT doesnt.
Old November 4th, 2011, 11:55 PM   #17
Theres alot of people that know alot more! But I do alright usually lol
Old November 5th, 2011, 12:14 AM   #18
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
He does. But 29* is way too much NA. The 2V heads arent near as efficient as the 4v heads and 29* is the borderline for power...and 28* is too much on juice.
Nitmare....that table unless im too hammered shows alot of '50's....thats not a true Borderline Knock Table...unless you use the MBT as your true spark table. which would be backwards. I would max out my MBT and then use my BKT as my timing table...
enlighten me.
(no sarcasm at all)
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old November 5th, 2011, 01:12 AM   #19
Its the spark borderline table. There really is 50 degrees of spark advance under some of those load settings. Thats where your fuel economy comes from.
There is also an MBT table and depending on the ECU and vehicle it will or will not be used. Many vehicles use both tables and default to the lower spark advance between the two tables. In those cases you will usually find the ECU follows the MBT table under part throttle settings and the spark borderline table under WOT settings. You will also find on GM and some others borderline spark table, knock table and MBT table. The MBT table is also used for torque calculation to determine how close the engine is running to spark for peak torque
Old November 5th, 2011, 01:46 AM   #20
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
my timing is around 25 on motor and 22 on spray for what its worth
cams + 150 shot
Threads Similar to: too much total timing for nitrous? i think so...
timing with nitrous. militarymustang V6 Mustangs 3 May 16th, 2011 07:53 PM
nitrous and timing travis00 94-95 5 April 22nd, 2010 03:20 PM
Nitrous and what should I set my timing at Steves LX General Tech 2 September 28th, 2007 06:51 PM
Nitrous Timing zerofx150 99-04 5 April 26th, 2007 10:11 PM
Timing Adjust For Nitrous ChrisJ General Tech 7 July 18th, 2006 09:25 PM
