centri blown 99-04 drag times?
LinkBack (1) Thread Tools
Old November 5th, 2011, 12:11 PM   1 links from elsewhere to this Post. Click to view. #1
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
i know this is a more of a drag thread than a tech thread, however, i'm trying to see what kind of times i should be able to run with my power. if a mod thinks it needs to be moved, please feel free to do so. and i'm only asking for centri blown cars so i can basically straight up compare them to my times.
so i'll ask you post up the following:
-what blower
-what psi/power level
-what rear end gears
-what tires, and what psi are you running them at
-auto/manual
-suspension mods
-launch rpm
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm
-weight if you know it with driver
-level of drag experience
-60 ft, 1/8th mile and 1/4 mile times and mph
-any other pertinent information you think i should know about the car.
i know this is a lot to digest, but i'm trying to learn how to drag race in a built, cammed, and blown motor car. it has quite a steep learning curve lol. i should have started before i got the blower on the car 6 years ago.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old November 5th, 2011, 12:35 PM   #2
redrocket's Avatar
redrocket is on a distinguished road
havent run my current setup but i ran the 1/8 in 7.53 at 97mph with a m/t et street radial 28in tall. built rear end with 3.73 gears, v2 si trim at 13psi. 485rwhp 60ft was 1.8and its a 5 speed 5k rpm clutch dump with 14psi in tires. I crossed the line in third. not sure on weight.
RET tuned 718rwhp/588tq
Old November 5th, 2011, 12:53 PM   #3
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Blown GT "redrocket" 18th mile pass @ Barona - Car Videos on StreetFire
God dam that mph is nuts!! Would have liked to have seen what a true 10" slick on the back would have done.
Mine went 7.48 @ 91mph with a 1.71 60', d1sc 3.2" pulley, 3500stall(3000rpm stall and 4500rpm flash off the line),stock 3.8l, and blower cam. It was making about 420 wheel.
New setup has been 7.32 @96mph with a 1.59 60'. Making around 450 wheel with a turbo.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old November 5th, 2011, 01:15 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
-what blower - V1 s trim
-what psi/power level - 9psi 380/380
-what rear end gears - 3.73
-what tires, and what psi are you running them at - 275/40 17 toyo proxes tq
-auto/manual - 5 speed
-suspension mods - none
-launch rpm - 4000rpm slipping
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm - 6300rpm - -weight if you know it with driver - maybe 3650??
-level of drag experience - over 140 passes
-60 ft, 1/8th mile and 1/4 mile times and mph - 1.90, 8.09 @ 91.39mph and 12.35 @ 114.5mph
-any other pertinent information yo think i should know about the car.
I like this good idea!
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old November 5th, 2011, 01:44 PM   #5
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
-what blower: Vortech V1 S non-intercooled
-what psi/power level: 9psi, 356/371
-what rear end gears: 4.10
-what tires, and what psi are you running them at: 275/50/15 BFG DR 16psi
-auto/manual: 5spd stock clutch
-suspension mods: Steeda Sport Springs, MM HD LCA, FRPP UCA, MM frame connectors
-launch rpm: 5,000 rpm dump
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm: 6000rpm, 3rd at 1/8th don't know the rpm, 4th in 1/4 at 6,000rpm
-weight if you know it with driver: 3,575lbs
-level of drag experience: around 50 passes in 5 years
-60 ft, 1/8th mile and 1/4 mile times and mph: 1.86, 8.29 @ 84.5, 12.81 @ 110.47
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old November 5th, 2011, 01:46 PM   #6
PeteGT's Avatar
03
11.91@113
PeteGT will become famous soon enough
-what blower -Procharger D1sc
-what psi/power level - 9lbs/413
-what rear end gears -4.10
-what tires, and what psi are you running them at -Mt Et streets Bias plys 14psi
-auto/manual -manual
-suspension mods -Upr k, 220lb coilover springs up front, Strange struts all corners, lca,sfc
-launch rpm -off the 2step at 5700
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm-4th for quarter @5600rpm
-weight if you know it with driver -3250lbs
-level of drag experience-200+passes
60' 1.645
330 4.913
1/8 7.617
mph 94.7
1000 9.956
1/4 11.917
mph 113.35
Has seen 122mph before too @ 12.03
Built motor/low compression, Built rear end, stock trans,
[url]http://www.youtube.com/watch?v=PTFyQGmctJA
Old November 5th, 2011, 01:54 PM   #7
2000 gt
if anyone thinks of any other variables that need to be placed in please do so
HARDCORE CREW
Old November 5th, 2011, 03:58 PM   #8
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
-what blower P1sc
-what psi/power level 9-10psi
-what rear end gears 3:73
-what tires, and what psi are you running them at 16in MT ET Street 16psi
-auto/manual Tr3650
-suspension mods Steeda upper/lower control arms, subframes, tokico shocks
-launch rpm 4500
-weight if you know it with driver 3300ish
-level of drag experience 150+ passes
-60 ft, 1/8th mile and 1/4 mile times and mph: Couldnt find my timeslip
But it was a low 1.8 60' high 12.3 @ 112mph. 5000+ft elevation
Bolt on list in Garage..
Old November 5th, 2011, 04:49 PM   #9
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
mounder27 will become famous soon enough
what psi/power level-vortech s trim 15 psi/ 400 rwhp
what rear end gears - 4.30
what tires, and what psi are you running them at -28" mt et street
auto/manual -auto
suspension mods -solid every thing, anti roll bar, relocated uppers, upr k member, strange shocks and struts.
launch rpm -4200
shift rpm/what gear you cross the 1/8th and 1/4 milestripe in and at what rpm -6500 crossing at 5500
weight if you know it with driver - ??
level of drag experience -racing since 2006
60 ft, 1/8th mile and 1/4 miletimesand mph 1.50, 6.92 @ 99 best mph 101
www.wmdracing.net
Old November 5th, 2011, 06:21 PM   #10
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
-what blower: P1SC
-what psi, power: 8.9 psi, SAE 383/370
-what rear end gears: 3.73
-what tires and psi: 315/35-17 Nitto 555R, 20 psi
-auto/manual: stock T45, Centerforce DF clutch
-what suspension mods: UPR UCA/LCAs
-launch rpm: 3000 rpm, bogged down on launch
-shift point: 6000 rpm, 3rd gear for 1/8, 4th for 1/4
-level of drag experience: 16 passes total (only 5 on DRs)
-weight: est. 3600 lbs?
- Best times:
.....60 ft: 1.942
.....330: 5.446
.....1/8: 8.269 @ 88.43 mph
....1000: 10.699
.....1/4: 12.73 @ 111.38 mph
The car is faster than this. I had a 1.85 60 ft. once but missed third.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 5th, 2011, 06:43 PM   #11
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
How fast you go depends on how brave you are and what tires you run. You push a 1.5 or faster 60than foot your going to cook a fast 1/4 mile.
bone stock from the factory!
Old November 5th, 2011, 08:03 PM   #12
11.463@121.50
saxmanJJ will become famous soon enoughsaxmanJJ will become famous soon enough
-what blower --- Vortech V3 NON-INTERCOOLED
-what psi/power level --- 12psi/451rwhp/408rwtq
-what rear end gears --- 4.10
-what tires, and what psi are you running them at --- MT ET Street Radial 275/60/15
-auto/manual --- manual
-suspension mods --- adjustable struts and shocks, no swaybar in front, MM double spherical rear LCAs, battery in trunk
-launch rpm - 4500
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm --- 6499, 3rd, 4th (6000 roughly)
-weight if you know it with driver - about 3500
-level of drag experience - 3yrs
-60 ft, 1/8th mile and 1/4 mile times and mph --- 1.54, 7.37 @ 96mph, 11.54 @ 121+ mph
-any other pertinent information you think i should know about the car --- removed everything from the trunk, removed the passenger seat, removed the rear wing, no wiper blades (LOL); MMR stage II ported heads, full-exhaust, Comp 262 cams
shooting for 11.39 tomorrow in COLD air !!!
MM Bracket Racing Crew Member #5
Old November 5th, 2011, 08:26 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
i wanna play!
-what blower - whipple 2.9L (twin screw)
-what psi/power level - 18# 640hp 577 tq
-what rear end gears - 3.55's
-what tires, and what psi are you running them at - 26x10x15 hooser drag slicks 12 psi
-auto/manual - manual t56
-suspension mods - upr upper and lower rear control arms, 3 way ajustible moroso mono tube shocks, fox body springs, edelbrock sway bar. front is all stock
-launch rpm - 4500 (2 step)
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm - 1/8th 3rd at 6200 rpm.
-weight if you know it with driver - 3700+ with driver
-level of drag experience - noob in this car
-60 ft, 1/8th mile and 1/4 mile times and mph - 1/8th only 60' = 1.75 mph = 101 1/8th time 7.04
-any other pertinent information you think i should know about the car. - cobra
old track vid, will be back at the track next week
Old November 5th, 2011, 08:51 PM   #14
2000 gt
Not fair 4 valve owner!
HARDCORE CREW
Old November 5th, 2011, 09:33 PM   #15
stal94gt's Avatar
2003 mustang v6 ;)
slow
You sure know how to break a mans heart
Old November 5th, 2011, 11:24 PM   #16
2001 Mustang GT
12.70@ 113.50
Rich11 has a spectacular aura aboutRich11 has a spectacular aura aboutRich11 has a spectacular aura about
-what blower -- Vortech V2 SQ Trim
-what psi/power level -- 9psi 403/403
-what rear end gears -- 3.27 FTW!!!!
-what tires, and what psi are you running them at -- Full pressure
-auto/manual -- Manual
-suspension mods -- Bone stock
-launch rpm -- Depends on track prep between 25-3500
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm -- 6250 shift, topping out 3rd at the end of the track.
-weight if you know it with driver -- ~3600 full weight with gas
-level of drag experience -- ~50 passed
-60 ft, 1/8th mile and 1/4 mile times and mph -- 1.9, 8.3@86, 12,70@112
403rwhp/403rwtq.
M.A.D. #11
Old November 6th, 2011, 11:13 AM   #17
11.6@118
thereal2v2fear is on a distinguished road
-what blower v2 s trim
-what psi/power level 9 psi 421hp/417trq
-what rear end gears 3.73
-what tires, and what psi are you running them at. Hoosier slicks 10 psi
-auto/manual manual
-suspension mods u/l control arms
-launch rpm 5500
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm 4th gear.
-level of drag experience. None
-60 ft, 1/8th mile and 1/4 mile times and mph 1.6 60ft 11.6 @ 118
02' Mustang|MMR 4.75L 1000se|Vortech|pump gas|566rwph/511rwtrq.
Old November 6th, 2011, 11:32 AM   #18
40thAnnivGT's Avatar
12.35 @ 116
40thAnnivGT will become famous soon enough
-what blower: V1 S trim
-what psi/power level: 13.5-14psi 418rwhp, 410rwtq (mustang dyno)
-what rear end gears: stock 3.27s
-what tires, and what psi are you running them at: 275 Nitto 555R's 15psi
-auto/manual: manual
-suspension mods: stock
-launch rpm: 4000rpm 2step
-shift rpm/what gear you cross the 1/8th and 1/4 mile stripe in and at what rpm: shift at 6100-6300, not really sure what gear i cross 1/8th, but i am like 100ft short of the quarter mile line before i have to shift into 4th
-weight if you know it with driver: 3600ish?
-level of drag experience: 100 passes or so
60ft 1.9
1/8th 8.1 at 88.5
1/4 12.35 at 116
-any other pertinent information you think i should know about the car:
forged shortblock, 9:1 CR, stock HCI setup, longtubes..
Vortech boosted MMR900 and supporting mods
420rwhp 410rwtq loaded Mustang Dyno
Turbo boost in progress
Old November 9th, 2011, 05:23 PM   #19
11.463@121.50
I ran a new best on Sunday: 11.49!
Broke 11.50 which was one of my goals.
Woohoo!
Next goal is to get the 60' down to 1.49 ...
Old November 9th, 2011, 05:49 PM   #20
12.73@111.36
Good time. Now you need a roll cage.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/238579-centri-blown-99-04-drag-times.html
What 0-60 times are people running (with blowers)? Just curious - MustangForums.com This thread Refback November 14th, 2011 09:08 AM
Threads Similar to: centri blown 99-04 drag times?
drag strip times!!! BlkGt03 99-04 22 October 1st, 2011 04:30 PM
new drag times will2045 99-04 4 September 20th, 2011 04:06 PM
drag times question 89greenstang 5.0 Mustangs 11 May 18th, 2011 10:06 PM
Drag times from last Saturday mounder27 Drag 0 August 15th, 2010 01:09 AM
1/4 Mile Drag Times barksdaleammo 99-04 23 March 27th, 2007 01:48 PM
