2003 Mustang GT
Brake problems, pedal is spongy
I bought a set of cobra calipers and put them on the other day and bleed them and the pedal was still mushy, in the process i sucked air through the master cylinder and had to bleed all 4 corners. I bled each wheel RR, LR, RF, LF. in that order and didnt see anymore air in the clear line. Couldnt figure it out and the mechanic at the shop i was at said he though the calipers where the problem so i swapped them out and put my old ones back on and still couldnt get it to work
so now im still stuck with stock calipers and rotors and now they dont work either, i dont know what to do. On the bright side i went through almost 2 quarts of brake fluid trying to get it figured out so now it has fresh fluid in it. any ideas on what in the world could still be causing this? and forgot to add my abs light was going on and off before I worked on the brakes and now its on and hasnt went off edit: after reading up on things, i think it might be the master cylinder with air in it. seems like the most logical choice.
Military Crew U.S. Navy/ATAA NAS north island
2003 ford mustang gt
13.9 stock
did you bleed your master cylinder and your abs system?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
2003 Mustang GT
no i didnt bleed either one, im going to bleed the master cylinder tomorrow but i cant find any info on bleeding the abs system. best thing i found was hit your brakes on a slick surface to kick the pump on lol. have no idea if they would even work
2003 Mustang GT
fixed it today, bleed the master cylinder and had it going in 10 mins. works great now, installed the cobra brakes again after i found out that was the problem and everything works. only thing is abs light is still on.
Threads Similar to: Brake problems, pedal is spongy
| Brake pedal issue | PhillyGT | 5.0 Mustangs | 6 | October 6th, 2010 05:13 PM |
| pulsating brake pedal | 100GT03 | 99-04 | 24 | September 17th, 2010 06:33 AM |
| Brake pedal gets stiff when A/C is on? | throwedoff | 99-04 | 1 | June 22nd, 2007 10:51 PM |
| Brake Pedal Squeek | 2000v6 | V6 Mustangs | 2 | September 17th, 2006 07:40 PM |
| Brake pedal switch | OTreborO | 5.0 Mustangs | 2 | August 29th, 2006 05:47 PM |
