75 mm Throttle Body, Plenum, 90mm Maf
Old November 6th, 2011, 12:12 PM   #1
03fastgt is on a distinguished road
I just got these parts for a steal used and wondering if I'll benefit from them and if it will run nicely. I've heard I need to change the injectors aswell to match it with the maf? I dont understand...
The car is being sprayed 125 shot....
Thanks
Old November 6th, 2011, 12:23 PM   #2
Shake N' Bake
supermachone's Avatar
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
what else do you have done? usually basic bolt on GT's wont benefit from bigger throttle bodies, as they are designed more for forced induction, not naturally aspired engines because they do not provide the increased air flow the TB is designed for
and since nitrous isnt really forcing more air into your engine, im not sure it will benefit you much, especially because the FI isnt there all the time as compared to a super or turbo
correct me if im wrong though, i would have went with a 70mm
BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1
Old November 6th, 2011, 12:36 PM   #3
Jaa1456's Avatar
2000 GT
Jaa1456 is on a distinguished road
Everything I have heard is not to go past a 70mm on a bolt on car.
Old November 6th, 2011, 12:58 PM   #4
Yeah, maybe I'll just keep the parts on the shelf until I supercharge it.
Old November 6th, 2011, 03:06 PM   #5
Matt86's Avatar
03 GT
Matt86 has a spectacular aura aboutMatt86 has a spectacular aura about
Id throw the plenum on now
Vortech v2 si-TiAl Q- CXRacing- still need MAF
Old November 6th, 2011, 04:40 PM   #6
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
The argument against the 75mm TB is the velocity vs. volume discussion. For high rpm cammed motor that might be a problem. But I've heard it not so much of a problem on basically stock cars. The 75mm TB/plenum will probably give you 2-3 rwhp and a lot of people report better throttle response with it. If you disconnect your battery before you start the swap, reconnect it when you are done, and let the motor idle for about 10-15 minutes, the ECU will relearn the new parameters.
The MAF will require a new tune and is of no benefit to you at this time. You stock MAF is good to around 360-370 rwhp.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 6th, 2011, 04:46 PM   #7
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
yeah dont throw the maf on, however might as well put on the tb/plenum. I have a 75mm on mine, sounds like a very similar setup, and i have zero issues.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old November 6th, 2011, 04:52 PM   #8
Thunderscrash's Avatar
2000 GT
N/A
Thunderscrash is on a distinguished road
I did a plenum and cold air intake. Didnt really notice too much hp gains but my gas mileage went up about 3-4 mpg's
Old November 6th, 2011, 05:22 PM   #9
Thanks guys,
Yea bottled2v we have pretty much the exact set up, except for the penguin in the trunk.
What gaskets will I need to install this? Looks like TPS and 2 other sensor spots, and the plenum---> intake gasket.
Just get them at the ford stealership?
Old November 6th, 2011, 05:34 PM   #10
11.85@116
you can prolly get by with reusing your stock one as long as you dont rip/tear the iac or tps sensor gaskets. the plenum gasket should be fine also.
Old November 7th, 2011, 02:46 PM   #11
I just put the throttle body and plenum on this morning and it runs as good or better than stock. After some acceleration testing I noticed a little more power around 4k rpm, may have lost some down lower though, but I could say there is some increase overall..
Thanks guys
Threads Similar to: 75 mm Throttle Body, Plenum, 90mm Maf
90MM Throttle Body on a 4.6 99GT35thLE 99-04 15 November 26th, 2010 01:27 PM
BBK 78mm Throttle Intake vs Accufab 75mm Throttle Body/Plenum andrewskaggs 99-04 19 June 11th, 2010 08:48 AM
75 MM throttle body and plenum, HELP stangman92 99-04 23 November 20th, 2009 04:05 PM
C&L Plenum vs BBK 78mm throttle body/plenum rider4life350 99-04 29 October 25th, 2009 05:25 PM
