Removed ecu now car won't start
I had removed the ecu to make the wires look clean. Put the ecu back in and the car would not start. Security light just keeps flashing real fast
13.7@103
Well, considering you probably cut and spliced wires. you better start redoing/checking all your wires.. I don't even know why you would attempt this.
A connector could also be loose. they really need to be connected tight. Goodluck...
![]() Bigbore Kooks (parting out 2v motor) N/A 5.3 4v Build
http://www.moddedmustangs.com/forums...ing-build.html |
is everything plugged back in? double check it all. sounds like theft mode keeping it from cranking, especially since the lights flashing fast. unplugging it all shouldn't cause the pats module to lose it's programming, so make sure everythings plugged back in. if it is, looks like you'll have to take it to the dealer to reprogram your keys. they should only charge you 1/2 hour to do so.
edit: you may be sol now anyways, because the computer see's that a theft's been detected so the cars immobilized. recheck everything you did and you'll prolly have to get it towed to a dealer.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
youve tripped your pats system. have fun
why would you do this? its all hidden behind the kick panel anyways, clean or dirty unless your superman with x-ray vision
#6 | |
13.7@103
#7 | |
2003 ford mustang gt
13.9 stock
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
go luck with your PATS functioning.
![]() Sig by Tricep |
#9 | |
2003 Mustang GT
![]() Seriously though, that made no sence to me at all
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
probably connector not seated all the way
![]() RET tuned 718rwhp/588tq |
I did it because the push tab was broken and the kick panel does not stay on, and I was just zip tieing them together. So how much does the dealer charge to flash them
unplug it and make sure you didnt bend any of the field mouse dick sized pins. Then if those are all straight make sure the connector is seated all the way.
You would have been better just getting a new panel instead of cleaning the wires lololololololol a zip tied panel seems a lot better now than a car that wont run
#13 | |
2003 Mustang GT
hahaha dude your little comparisons are fucking hilarious
my dealer charges 1/2 hour for a key reprogram, at our shop that's 42.50 so it all depends what your dealer charges an hour.
Threads Similar to: Removed ecu now car won't start
| Having Cats removed on an 06 gt | 06Black5spdGT | 2005 - 2010 | 4 | July 31st, 2008 11:33 PM |
| how much weight have i removed? | Twist it up | 5.0 Mustangs | 31 | October 21st, 2007 09:03 PM |
| cat converters removed | Pharoh | V6 Mustangs | 2 | July 21st, 2007 09:04 PM |
