Researching Vortech Kits - Page 2
Old November 11th, 2011, 08:02 PM   #21
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
A non intercooled kb is the biggest POS that should have NEVER BEEN MADE. Running a TS with no intercooler is nothing short of insane.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 11th, 2011, 08:43 PM   #22
joswo1980's Avatar
2001 mustang gt
no clue
joswo1980 is on a distinguished road
^ I second that running a top mount blower wo a intercooler isn't a very good idea
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
Old November 11th, 2011, 09:22 PM   #23
IsaidWOT's Avatar
IsaidWOT is on a distinguished road
So the consensus is still Vortech?
2002 Mustang GT | Short Throw Shifter | CAI | 3.73 Gears | Exedy Mach 400 Clutch
Old November 11th, 2011, 09:39 PM   #24
T-Lee. 30's Avatar
03 gt, 96 tbird, 05bv gxp
Faster than trolls!
T-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really nice
Send a message via Yahoo to T-Lee. 30
either a non ic vortech for like 3grand or the intercooled kd for almost 5grand. there are plenty of cats on here running the vortech and would advise you to go ahead and run that vortech and dont look back. hell even a v1 s trim $3014 mhs or cms stage 1 blowe cams $595 cx racing intercooler $200 =$3809 is even cheaper than a non ic kb blower and over $1000 cheaper than th intercooled kb with all of that along with the vortech.
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
Old November 11th, 2011, 09:42 PM   #25
joswo1980's Avatar
2001 mustang gt
no clue
If u wanna keep on a good buget and only want 400ish hp then vortech is way to go then u can throw a cheap cx intercooler on it and bov and it will sound nasty as hell but unless u got 1000's to spend on a INTERCOOLED KB then I would stick with that
Old November 11th, 2011, 09:44 PM   #26
Kevin C's Avatar
2001 Mustang GT
34.82 @ 21
Kevin C will become famous soon enoughKevin C will become famous soon enough
OP, you could always buy my V1 setup for 2K!
Includes:
V1 S-trim head unit
2000-2004 bracket
All bracket bolts
3.6" pulley
Idler pulley
Belts
Oil feed line
Oil return line
39LB OEM 03-04 Cobra EV6 injectors
EV6 injector to EV1 harness adapters
Intake assembly
Discharge pipe
Vacuum line and T fitting for boost gauge
Vortech bypass valve
90MM MAF
All clamps and couplers
SCT 4 Bank chip
Original Vortech chip
Full set of original Vortech instructions
Just needs a filter, missing one little fitting for the oil lines, and one of the big bracket bolts might be missing. I think it probably just fell out of the container it was in when I picked up the box and got it in the Mustang to get a shipping quote.
Could also include an SVT Focus fuel pump for a little extra.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates
Vortech V1 sold
Old November 11th, 2011, 09:46 PM   #27
joswo1980's Avatar
2001 mustang gt
no clue
Or u could do that ^ save urself a few grand
Old November 11th, 2011, 10:37 PM   #28
IsaidWOT's Avatar
I'd love to except I just dropped $1,300 on tuition. Let me recoup and fix the little problems (bad clutch and exhaust) and hopefully by next fall I'll have the dough. Right now I'm just making a list and checking it twice.
I know, that ^ was dumb.
Old November 11th, 2011, 10:52 PM   #29
I would go vortech personally. Unless your buying the fully loaded KB kit then its not worth it. I personally dont believe the 2.1 KB is a 6k dollar blower. I've driven several cars that are KB and the instant torque is fun but an SI head unit has so much more potential and you can do so much more with so much less. The CX racing intercoolers are good but for just a little more money you can buy a treadstone and have a very nice intercooler with like only 1lbs of boost drop. I'm also switching to air to air and I have probably the highest efficiency intercooler setup money can buy right now. I'm only changing because I'm going to be running 16+lbs of boost and I cant get a big enough BOV on my aftercooler without chopping it up big time and I would rather just sell it and move on. If you buy a vortech kit just hold on for a bit because my aftercooler kit with the killer chiller will be for sale for a good price.
Check out the treadstone TRV25 intercooler. They really are a great intercooler
Old November 14th, 2011, 10:16 PM   #30
Bullitt5566's Avatar
2001 Mustang Bullitt 5566
Bullitt5566 is on a distinguished road
I bought my V2 setup from Black Bullitt on this form for $2400, and went from there. I tapped my own oil pan and it wasn't too difficult. The kit came with an aftercooler, but an intercooler will work just as well. At 10psi either will work fine. Personally I'm partial to the aftercooler because I have a 5 gallon trunk mounted tank that I pack with ice for autocross runs, drag passes, and dyno runs, but I also have a heat exchanger to keep the water cool during day to day driving. Just make a list of parts you need, injectors, fuel pump, so on, and keep an eye out for them in the classifieds. Buy everything piece meal, and install it when you're ready.
True Blue Bullitt 517hp 456tq
Vortech
| Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC
Old November 14th, 2011, 10:18 PM   #31
Hey NitMare, I'll take that Chiller off your hands for the right price.
Vortech
Threads Similar to: Researching Vortech Kits
Vortech V3: alternative A/W intercoolers to Vortech system? saxmanJJ 99-04 5 November 3rd, 2011 02:58 PM
vortech supercharger kits momogt 99-04 13 June 28th, 2009 04:19 PM
So I'm researching on what gears to get. Huxley 99-04 39 February 27th, 2009 08:00 PM
how are the jms vortech supercharger kits??? lilmarc1988 99-04 3 March 2nd, 2008 08:53 AM
Vortech kits without a tuner??? catchtheroadrunner General Tech 4 October 17th, 2007 07:17 PM
