Researching Vortech Kits
I have gears installed, so I'm not looking for a ton of low end power. Been checking out Vortech kits. Summit Racing has the V-1 kit for $3,014.95. This is a good price from what I've seen.
American Muscles' kit is the V-3 though. Should I hit up that one instead? Is there much of a difference for an additional $700? It says it's self lubricating, whereas I'm assuming the V-1 isn't. Just trying to get all my ducks in a row. Thanks!
2002 Mustang GT | Short Throw Shifter | CAI | 3.73 Gears | Exedy Mach 400 Clutch
I have the v1 s trim kit and love it as far as self lubricated vs the oil tapped units like the v1 and v2 they tap into the oil pan so the suck from a supply of 6qts or however many qts you put into your car and its all cycled through the filter since its your engine oil. the self contaned just has that few ounces of oil in it that just stays in the head unit no oil filter, oil cooler or a deep supply of cycling oil coming from the pan and when you change your motor oil the unit also gets fresh oil along with it. there is a member on here that was able to get over 600rwhp with a v1 strim and blower cams with the supporting fuel mods. So its a great blower for the price and being 500-600rwhp capable is plenty for the streets. I have 3.73 gears and an auto with my v1 s trim its not that bad on gas either I just drove from Killeen tx to Tifton Ga and averaged 23mpg highway cruizing between 75-90 most of the way with luggage and a 15" sub in the trunk.. I only put down 339 rwhp/359 rwtq on the dyno @4-5psi I had a bad belt tensioner though it was my factory old one so I went to a parts store and picked up an aftermarket tensioner for like $45 and now it goes from 7-9 psi but it hasnt been back on the dyno but with the extra 2-4 psi its obviously more than 339rwhp/359rwtq now. all through an auto with a catted x and 10 series flows. my base dyno before the blower was put on was 233rwhp 266 rwtq so 106 hp increase/ 93 ft lbs increase with a crappy tensioner.
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
#3 | |
Authorized Vendor
![]() 1987 Mustang LX 5.0
The V-3 kit is a great improvement over the V-1s and 2s and a lot of this has to due with the self-contained lubricating system. This saves A TON of headaches in terms of having to tap your oil pan. That doesn't sound like a huge deal, but when you consider that the engine has to be lifted from it's mounts to remove the oil pan, that is a couple hours labor at least. You also then have to trust the quality of work of the person drilling/tapping/welding the bung in place in the oil-pan AND you have to get the required lines/fittings necessary to use the new bung in the oil-pan. Speaking from experience, the V-3 kit is just a cleaner/easier installation and in the long-run is definitely a worthwhile upgrade. Furthermore, the head-units(supercharger impeller/impeller housings) are all the same size and flow the same amount of boost through all three models, so you will not see a "performance" improvement between them. They will all make the same power, it just comes down to how easy you want the install to be. Good luck! I hope this helps! Please let me know if you have any questions in the future!
Chris Young | AmericanMuscle.com Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST GET UP TO $200 TOWARDS YOUR NEXT PURCHASE FROM AM! Free Same-Day Shipping! |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
All si models flow the same but the v1 head units have a lower step ratio so the sc will make less boost per pulley. The v3 si is by far my favorite entry level sc and not running motor oil threw it is a good thing. It keeps all the engine contaminates out. Also a v3 si tuner kit can be had for 2800 off summit.
![]() bone stock from the factory! |
Sorry to butt in here, but Rockwell29, which member is making 600HP on the v1? I'd like to see what his set up is like. Thanks
2003 mustang v6 ;)
slow
Jivepepper spun a v1 s trim with heads cam and a mmr 900 to break 600a but it was over spun quite a bit. Now he runs a t trim.
2003 mustang v6 ;)
slow
Btw I ran a v3 si trim with ported heads, STOCK cams, and a mmr 900 with a stock lower and a rr3.0 pulley and made mid 500's not over spinning my v3. The v3 is one of the few perfectly matched blowers for a modular cause with the stock 3.6 pulley it makes exactly 10# on a stock motor non ic. Which means it can be used from mild to wild
#8 | |
#9 | |
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
So the tuner kit just doesn't include the tune, injectors, fuel pump and stuff. Instead of going that route, I'd probably do the sticky for the affordable supercharger. I dunno, it's probably a year out yet since I just had to pay another $1,300 for tuition this week.
you can always check out the classifieds on here if you dont want to pay the price for the brand new kits. The kit i picked up is the same one you listed for $3014 but i found mine on craigslist out in houston for $2400 brand new and complete still in the box wrapped up. Just do a bit of weekly hunting close to the time you're planning on picking one up.
2002 mustang gt
i bought that same kit from summit and installed it myself. i love the kit and it works great its no big deal to tap the oil pan. just make sure you get a dyno tune because the tune they put on my computer was running rich and making like 50 less hosepower. i have had that kit on my car for almost two years and never had any problems yet. you all so get a 3 year warrenty from vortech with that kit.
324RWHP 323RWHP 8.1 psi. BOOST
#13 | |
2001 mustang gt
no clue
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
One more question for you guys, I'll probably go with the V3 when I get the money. What octane fuel do you use with your S/C?
93!!!!!! or the highest in your area.
Okay, yeah we have 91-93 here.
Okay, call me a woman, but I've changed my mind. I'm going to go Kenne Bell. After looking at both extensively I'll probably go with a Non IC kit because my power requirements aren't that great. I want more than 300rwhp, but less than 400rwhp. Wife will never let me do much beyond.
With that said, the KB just has the look and sound that I'm wanting. I won't need it intercooled because I don't want higher output than about the 340-360 it'll give me.
#18 | ||
I prefer a Sc the use an external oil supply. They are more durable. That's why all race centrfuge blowers and turbos still tap into an external oil supply. Now the improved impeller design it why it's an improvement.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
haha yup. You'll get bored with 350rwhp real fast. The KB may hold you over for a while because of the instant boost so it will feel fast, but in a month or two you are going to want to up the boost. In no time you will be putting an intercooled kit on it.
I run the V3SI and wouldnt have it any other way. Best entry level blower on the market by far.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Threads Similar to: Researching Vortech Kits
| Vortech V3: alternative A/W intercoolers to Vortech system? | saxmanJJ | 99-04 | 5 | November 3rd, 2011 02:58 PM |
| vortech supercharger kits | momogt | 99-04 | 13 | June 28th, 2009 04:19 PM |
| So I'm researching on what gears to get. | Huxley | 99-04 | 39 | February 27th, 2009 08:00 PM |
| how are the jms vortech supercharger kits??? | lilmarc1988 | 99-04 | 3 | March 2nd, 2008 08:53 AM |
| Vortech kits without a tuner??? | catchtheroadrunner | General Tech | 4 | October 17th, 2007 07:17 PM |
