2000 mustang GT
Clutch is finally installed but maybe some issues?
I just finished my clutch install, go to test drive and I notice when I start to release clutch I can actually hear it spin on the flywheel. Is this normal for brand new clutch will it go away. It also seems to make a strange noise when car is in fifth.
Did you change your throwout bearing and pilot bearing?
2000 mustang GT
Yes sir I did. What's happening is when I start releasing the clucth and it actually starts to grab I can hear it hit the flywheel. It's not loud or obnoxious. I don't have the rubber boot on yet or the shifter boot either so maybe they drown this noise out. It's not terribly loud I just hear the clutch engage I guess
2000 mustang GT
I'm pretty sure the clutch isn't releasing 100 percent with I push pedal down. Now on occasion I grind 4th and 5th. Pedal releases right off the floor. Could it be Mercon 5 or is it clutch adjustment?
My ram HDX clutch made a swoosh sound the first 2k miles as it broke in. Its just the clutch disk matting itself.
Most new tranni oil is synthetic which isnt great for a gearbox. I've tried several and had the best results by far with regular dexron/mericon non synthetic. It whinned a little with all others.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
2000 mustang GT
Mercon 5 is what ford told me to use and it whines in second pretty bad. It shifts smooth in every gear except 4 and 5 on occasion. This ram hdx cluTch grabs awesome though.
1992 Mustang GT
dont know yet
Does it kind of sound like sand paper on something when you first let off of the clutch? Or is it sounding like that the whole time.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
Thats mercon for you. Its because its synthetic now and it wasnt in the past. If you want it to stop whining run dex/mercon. Its one of the only mercon compatible non synthetics left on the market. Synthetic oil works great on bearings. Not so great in a gearbox. The oil WILL last longer which is what synthetic does. But it WILL wear out the tranny faster because synthetic doesnt cling to things as well as a standard dino oil..... It wont wear out overnight but it will get louder. I say switch it. The other issue is most trannys dont shift as well with synthetic because the oil isnt tacky enough for the synchros to function as well as with a dino oil or an oil with a friction modifier such as synchromesh
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
with a t45 run mercon 3 non synthetic.
![]() bone stock from the factory! |
I havent been able to find mercon 3 anywhere on the shelf which is why i ran the dex/mericon because its the closest to it. I wonder if its only a california thing?
2000 mustang GT
Here in ny we don't have mercon 3. Ill try dex merc
2000 mustang GT
I seem to still have this issue. It sounds like sandpaper when I engage clutch and also seems to make identical noise when in 5th. But I don't smell burnt clutch. Could it be the trans itself. Haven't changed fluid yet. The noise is only audible when shifte boots are off
2000 mustang GT
Just finished with the trans flush and replacing with dx merc. Most noise is gone but I grind down shifting from 5th to 4th. This car has never done this before. It only grinds if I'm revving at above 2k rpm in 5th and shift to 4th. Anything below it shifts smooth. I have no problems with any other gears and can rev to 6k in 3rd and up shift 4th with no issues wtf is going on Should I just double clutch to 4th on a down shift.
#14 | |
99 Cobra, 03 Mach1, 07 CS
http://images.mustangandfords.com/pr...lutch_fork.jpg http://www.fordforumsonline.com/foru...earing-002.jpg
![]() 2007 Redfire California Special http://i183.photobucket.com/albums/x...n/2007GTCS.jpg 2003 Dark Shadow Grey Mach 1 http://i183.photobucket.com/albums/x...born/Mach1.jpg 1999 Black Cobra Vert |
1992 Mustang GT
dont know yet
In my 96 I ran the ram hd and it made that sand paper sound when you let off of the clutch it is normal.
As for it making it in 5th gear is it a constant noise or is it just when you let off of the clutch into 5th Sent from my Autoguide iPhone app
2000 mustang GT
After running the dex merc for about 60 miles the fourth grind is gone completely. I can't hear any more noises because I put the boot back on the car now. Hopefully all is well.
Threads Similar to: Clutch is finally installed but maybe some issues?
| TH400 installed but issues | y2k02 | 99-04 | 5 | May 8th, 2011 11:42 PM |
| MM LCA Installed and now issues... | cardinales15 | 99-04 | 6 | June 20th, 2010 09:50 PM |
| installed new throttle body and plenum...issues | smokeshow | 99-04 | 43 | May 20th, 2010 12:08 PM |
| 4.10s Finally installed. | gragra73 | 2005 - 2010 | 32 | May 15th, 2008 03:42 PM |
| finally installed | spero | 99-04 | 5 | August 3rd, 2007 01:27 PM |
