Shake N' Bake
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Isolated My "Ticking" Problem
so i used a pool noodle as a stethoscope and the tick appears to me coming from what i believe is the crankshaft balancer, number 5 pulley on this diagram
![]() any ideas what to do next?
![]() BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1 |
wiggety wiggety whack!
Make sure its on tight, possibly buy a new one? Do you have underdrive pulleys?
Shake N' Bake
1984 Corvette
well i thought about replacing it but i just took the belt off and ran the car for just a tad bit and the tick is still there
![]() so now im assuming that means the sound is coming from inside the engine? i thought about purchasing U/D pulley's if i had to replace it ive had this issue for quite awhile, it all started when ford tried to program my computer to the 4.10 gears (they said they could but failed) ever since then its been on and off, after i replaced the idler pulley and tensioner assembly it went away for about 2 days but came back i was hoping i would be able to fix it myself but it looks like im just gonna have to take it to a shop and get ass raped in charges
![]() BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1 Last edited by supermachone; November 11th, 2011 at 09:55 AM. |
Is the pulley on good and straight, and not clipping anything? Does the ticking increase with RPM's?
You can check other things that would tick - spark plugs starting to loosen and the accompanying exhaust leak would be one thing, but since you are pretty sure its down by the pulley I can't really say. |
Bringing Yellow Back
maybe you need new timing chains?
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#6 | |
Shake N' Bake
1984 Corvette
i havent checked my plugs yet but I have a feeling it has something to do with the timing chains as zinc mentioned ive read somewhere they could have slack in them and can actually be making contact with the something inside the engine fucckkkk
#7 | |
Timing the 4.6L SOHC Engine |
check your plugs, they will tick then go POP like mine did lol
then if after that pull a valve cover and see how loose the chains are
#10 | |
Shake N' Bake
1984 Corvette
hopefully i can dig into the issue today while i have some time (and nice weather), after i reinstalled the belt the other day the tick went away again, but of course this morning its back
the fact that you pulled the belt off and the tick was still there doesn't eliminate a possible isue with the harmonic balancer as that ALWAYS turns when the engine is running as it is directly connected to the crank. Make sure it is tight, and with the belt on watch it to see if it has any wobble. If those are OK, a timing (cam) chain issue would be my next guess.
2001 Bullitt
These engines are notorious for timing chain issues, mostly the tensioners seize and the chain eats through the guide and into the tensioner. Take off v/c and shine a light down and check out the guides. It's not too bad of a job to do timing chains anyway so while your there you could do a set of cams...
01 DHG Bullitt Stroked, Forged & Blown Built Rear, Viper T56, Suspension, Drag Radials 374.6 rwhp 374.4rwtq @ 4.6L 10psi Now 5.1 and 15psi, no idea on the numbers!! |
Dancing Naked In The Rain
Pics of your using a pool noodle as an automotive stethoscope, now
2003 Mustang Gt
Slow
broken timing chain tensioner, so common
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
#15 | |
2003 Mustang Fauxbra
N/T @ Fast
Balancers tend to not make any noise, especially a ticking noise when failing. My money is on the tried and true collapsed lash adjuster if its actually an internal failure.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
Threads Similar to: Isolated My "Ticking" Problem
| "Soda Bubbles" paint problem. Please help... | ONLYaUNCfan | General Car Care & Detailing | 5 | September 28th, 2011 11:27 PM |
| is "ticking" common with our 2vs? | lehrskee | 99-04 | 25 | July 17th, 2011 04:21 PM |
| NEED HELP! Think i have a problem with "PATS" Passive Anti Theft System. | 1badSN95 | 96-98 | 5 | December 10th, 2010 09:33 PM |
| Classic "vents on defrost" problem | Atlus | General Tech | 1 | October 18th, 2008 09:23 AM |
