TBD
Steel backed straight timing guide issue
Just trying to find an opinion/option on what i can do. I upgraded to steel backed straight timing guides, i was told the only change i would have to make to use them was to get a shorter bolt because the guide no longer bolted into the oil pump, it bolts to the block. The issue im having is i dont have threads where its suppose to bolt to. Im using an 03/04 cobra block but my 00 GT block does not have it either. Should i drill and tap it or just use the plastic guide? Im only having the issue on the driver side, the passenger side is fine. Id prefer to use the steel mainly because its stonger, whats every ones thoughts?
I like boobs!!!
2000 GT convertible
dunno
Personally, I would be apprehensive about drilling into my engine block. I would just use the regular plastic one. I don't know what's behind that casting. Could be a water jacket, could be an oil galley, could be nothing. I wouldn't risk it. Also, how would you know that you are drilling in exactly the right spot?
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
TBD
im iffy about it to, nick said it was a simple bolt swap. Im still waiting for an email from him
TBD
bump
Threads Similar to: Steel backed straight timing guide issue
| 4.6 timing chain install guide help. | SS Ball3r | 99-04 | 5 | February 24th, 2011 08:51 PM |
| Timing chain guide issue.... | DegralDan | 99-04 | 6 | February 14th, 2011 02:34 AM |
| Timing Chain guide problems?? | jg42122 | 96-98 | 23 | March 16th, 2010 12:57 AM |
| broken timing chain guide | blown_97cobra | 96-98 | 18 | February 26th, 2006 09:57 PM |
