ABS lights, and others with gear install
Old November 11th, 2011, 10:33 PM   #1
Gdbyrd is on a distinguished road
Hey guys, so I bought this 01 Mustang last year as a project vehicle. It had ABS lights on, and the traction control will not work. The previous owner had had gears installed in it, and said that both issues had come up since.
It leaked diff fluid just sitting there, so I replaced the gasket and refilled it. Since then it has continued to leak, but it doesn't look like it's coming right from the diff cover.
Anyone have any advice for me?
I've still got a lot of little things to get done, but this and an airbag light are really bothering me.
Old November 11th, 2011, 10:39 PM   #2
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
are the tires the same size all around is it a staggered setup? The ABS light will be out of sync if the all the wheels are not spinning at the same speed, or close to it. The gear install has nothing to do with it with the exception that you have to remove the abs sensors during the install. it's likely something is not hooked up properly. Did the original owner do the install himself?
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old November 11th, 2011, 11:13 PM   #3
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
maybe they broke one of the ABS rings on the axles...
cams + 150 shot
Old November 11th, 2011, 11:15 PM   #4
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
If the tires/rims are all the same size, check your abs sensors as they are easy to break if someone was careless while removing the axles for the gear install.
Bolt on list in Garage..
Old November 11th, 2011, 11:25 PM   #5
He said he took it to a shop, but there are a TON of shade tree shops around here. The original tires had skinnies in the front and fatties in the back(45s/40s respectaviely), but I replaced the tires with the same size all around and still have lights.
Is there anything I can do from the outside to look into this?
Old November 11th, 2011, 11:26 PM   #6
I had read about those little things. Where are they located and what do they look like?
Old November 12th, 2011, 01:35 AM   #7
showoff is on a distinguished road
check the big fuse under the hood. i pulled mine out and now the ABS light is on and the traction control is off all the time
Old November 12th, 2011, 06:48 AM   #8
Jaa1456's Avatar
2000 GT
Jaa1456 is on a distinguished road
Why did you pull the fuse? And did you put it back in?
Old November 12th, 2011, 08:55 AM   #9
2000 GT 'vert
Nas
Threads Similar to: ABS lights, and others with gear install
Lights on after spring install sjones1088 2011+ 8 July 8th, 2011 05:21 PM
How to access lights in gear shift lever-2001 V6 Auto PacificMustang01 V6 Mustangs 0 February 19th, 2009 12:18 PM
head lights install hedgehog 4V / SVT 0 November 8th, 2008 11:53 AM
4.10 Gear Install!!! MustangJon255 2005 - 2010 1 October 4th, 2007 11:04 PM
[Install]Fog Lights DSEZ V6 Mustangs 14 January 23rd, 2007 02:29 AM
