Camshaft sensor in motor?
Old November 11th, 2011, 11:57 PM   #1
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
KevinJ99GT will become famous soon enough
So my car just got back from getting cams and headers installed with a check engine light on for camshaft position sensor. Thought no big deal just need to replace it. Tonight i went in to replace it and when i pull it out, its completely broke with thin copper strands hanging from it. The whole part that sticks in the motor is gone but its running completely fine. Ideas or am i eventually gonna be screwed?
- full bolt on's, hitech stage 2's, zex 100 shot
Old November 12th, 2011, 12:31 AM   #2
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
Hopefully it fell to oil pan no harm done right?
Old November 12th, 2011, 01:04 AM   #3
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
I would take it back to them and tell them now they can pull it apart again and find the pieces. Thats bs. Makes you wonder why it broke doesnt it?
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 12th, 2011, 05:50 AM   #4
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
If they just did cams, they probably used the timing chain tool to hold the chains in place while replacing the cams. When they were pulling the tool out they accidently hit the timing sensor and cracked it.
Did you get adjustable cam gears so they could degree the cams up top.
Drive it like you stole it
Old November 12th, 2011, 08:25 AM   #5
joswo1980's Avatar
2001 mustang gt
no clue
joswo1980 is on a distinguished road
If its just the little copper hairs ul be fine just let it idle for 10 minutes and change ur oil and filter, copper is soft and light
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
Old November 12th, 2011, 08:28 AM   #6
joswo1980's Avatar
2001 mustang gt
no clue
Opps just reread it and notice u said ur missing the whole magnet if half, u might just need to pull ur valve cover
Old November 12th, 2011, 10:31 AM   #7
KevinJ99GT's Avatar
1999 Mustang GT
8.30 1/8th mile
Whats weird is the motor runs perfectly fine just have a ses light on. Gonna replace it today, put fresh oil in her and hope it runs fine.
Sent from my SAMSUNG-SGH-I897 using AutoGuide App
Old November 12th, 2011, 10:36 AM   #8
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
I would not take the chance! It will most likely mess up and leave you stranded when your the furthest away from home! I would take it back and make them fix it since they did the work. If they don't I would take it to the B.A.R. I am not talking your local watering hole either! LOL
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Threads Similar to: Camshaft sensor in motor?
if a camshaft position sensor is bad.... BakerFX4 99-04 13 July 27th, 2011 03:49 PM
Camshaft sensor A?? GreenMustang00 V6 Mustangs 4 June 17th, 2010 12:21 PM
camshaft positioning sensor 1999.35mustang V6 Mustangs 2 October 9th, 2008 02:53 AM
Camshaft Position Sensor jagstang96 96-98 2 November 16th, 2007 11:05 AM
camshaft positioning sensor mmvi V6 Mustangs 7 August 4th, 2007 01:01 AM
