Seond Gear is being a b*tch
Old November 12th, 2011, 06:57 PM   #1
overnightmillionaire's Avatar
Mustang GT 2004
overnightmillionaire will become famous soon enoughovernightmillionaire will become famous soon enough
Send a message via AIM to overnightmillionaire
Hey Guys,
I just had new fly wheel, clutch, aluminum quadrant, throw out bearing, firewall adjuster installed by a shop.
When I take off from 1st (reved up to say 5k-6k RPMS) and try to shift into second it won't go in (it's very rare if it does), it will even grind some times. I don't have any issue with second gear when I'm driving like a normal person, it only happens when my engine's spinning high.
My clutch's engagement point is pretty close to the floor. No other gear has this issue... which is odd, and which makes me think it's not the low engagement point.
PS. Which way do I turn my firewall adjuster to raise the engagement point?
Thanks
Old November 12th, 2011, 07:00 PM   #2
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
turn it outwards.. mine was having a little trouble getting into second also and I just adjusted it with success. good luck.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old November 12th, 2011, 07:01 PM   #3
Mustang GT 2004
I can't tell which way is outwards, turn to left or right? In other words, counter clock wise or clock wise. lol
Old November 12th, 2011, 07:18 PM   #4
2000 GT 'vert
mine is counter-clockwise to turn it out.
Nas
Old November 12th, 2011, 09:44 PM   #5
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Turn counter-clockwise. This is the problem...... the clutch probably isn't disengaging enough. This adjustment will remedy the problem and make your problems disappear. You will be able to fine tune the clutch engagement point with the firewall adjuster.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old November 12th, 2011, 10:40 PM   #6
Mustang GT 2004
Thanks, sorry for all the questions, but did you have to keep starting your car to test the adjustment? Also how many clicks would you turn it counter-clock wise before testing the engagement point again, how many turns is a significant change to the clutch?
Old November 12th, 2011, 10:46 PM   #7
2000 GT 'vert
I start the car, turn it a bit and test the clutch feel. I've also go a freeplay kit so my adjustments probably feel and work a little different than yours.
Nas
Old November 12th, 2011, 10:54 PM   #8
Mustang GT 2004
Awesome, thanks!
Old November 13th, 2011, 08:34 AM   #9
bulloch27's Avatar
N/T @ Fast
Yeah, it's a trial and error kinda thing. Good news though, once you get it where it needs to be you're pretty much done. It will require some minor adjustments as the clutch wears but its not very often.
Old November 13th, 2011, 10:25 AM   #10
Mustang GT 2004
Yeah,
Have one more problem, my clutch rattles a bit when my foots off it. I can move it slightly left or right, or up and down (like 1/4 inch) but it's enough to have this annoying rattle when I'm idle.
Should I just tighten the bolt, I'm assuming it just got lose over time.
Thanks
Old November 13th, 2011, 07:55 PM   #11
bulloch27's Avatar
N/T @ Fast
Are you saying the clutch pedal is rattling? If that's what you're saying I've never had any issues with the clutch pedal rattling and if you have proper clutch cable tension on the pedal it wouldn't rattle.
Old November 13th, 2011, 08:26 PM   #12
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
Adjust the cable til there is no slack at the firewall adjuster.
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Threads Similar to: Seond Gear is being a b*tch
Rear Gear Swap Pricing and Gear Oil TStang 2005 - 2010 9 August 17th, 2010 06:09 PM
Cam gear and camshaft position sensor gear... 99v6stang V6 Mustangs 17 January 17th, 2008 02:00 PM
Does anyone use gear to gear timing? e3sean 5.0 Mustangs 24 December 27th, 2007 02:37 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 05:22 PM
