2001 Mustang GT
compression?
want to go heads an cam i was looking at trick flows 38 cc an 44cc but both raise compression too 10:1 i dont want to raise my compression because somewhere down the road i want to boost my car but if im going to boost my car then should i not bother with heads an just go for cams?
![]() BBK Shorty headers,O/R X pipe, Magnaflow Catback CAI Accufab 75mm throttle body C&L Plenum Tokico Lowering springs Trans go shift kit Soon:Comp Cams,SCT Tuner,3:73 Gears,MM Cast Chamber Plates |
both do not raise the compression..44cc will keep compression around the same 38cc will raise the compression to about 10:5:1
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
compression is ok with boost just make sure the timing and fuel are right for the set up. 10:1 and 7psi are doable on 91 octane. Get a meth kit and you can do better. Or go e85 and you have a nice setup
![]() RET tuned 718rwhp/588tq |
2001 Mustang GT
Oh i was just goin by what a/m said in the description Mustang Trick Flow Twisted Wedge Cylinder Heads - 44cc (96-04 GT) at AmericanMuscle.com - Free Shipping
1989 LX Coupe
7.1@99mph
44cc will lower the compression
38cc will help a little. mid 01-04 44cc stock shortblock...about 9.3:1 38cc stock shortblock...about 10:1 99-mid 01 44cc-8.9:1 ish 38cc-9.7:1 ish
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
Threads Similar to: compression?
| compression | riddlee josh | V6 Mustangs | 1 | May 27th, 2010 09:50 PM |
| Compression Help | Spoonep3 | 5.0 Mustangs | 6 | April 14th, 2010 10:23 AM |
| Compression? | Timm10221 | 5.0 Mustangs | 6 | April 6th, 2010 10:17 PM |
| How much compression? | bossman69 | Classic Mustangs | 2 | October 6th, 2008 07:59 PM |
| Compression | mustangmanic | 99-04 | 12 | October 10th, 2007 10:01 PM |
