low compression 2v question
Old November 13th, 2011, 03:29 PM   #1
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
joshdj13 is on a distinguished road
i havent heard about anyone running a low compression 2v and am interested to see if anyone is. i know they make less hp n/a but will they make alot more f/i like the termi's. just a question to pick your brains.
Old November 13th, 2011, 03:33 PM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
they wont make "more FI"
they'll just be able to make more FI with less chance of detonation. Termis run like what 8.5 compared to the regular 9.0?
410rwhp 520rwtq @ 12.9 psi
Old November 13th, 2011, 03:44 PM   #3
4v Know-it-all
na svt is on a distinguished road
lower compression means lower hp, lower tq, less power when off boost and reduced driveability.
Old November 13th, 2011, 04:03 PM   #4
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
ok thanks, i was under the impression that a low compression engine made more than stock compression at the same boost level.
Old November 13th, 2011, 04:06 PM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
for every point of compression i think it makes 4% more power. So going to stock cobra compression you would lose 4% power over a comparable car at stock compression.
Old November 13th, 2011, 04:08 PM   #6
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
no it will make less. more compression will always =more horsepower. it's just at what cost. everything has a trade off. higher compression will net you more power, but less safety with a blower/turbo. lower compression will resist detonation better, but will take more timing to make the same power, which can offset.
in todays world with better tuners/tuning abilities, there really isn't a reason to go to a lower compression unless you're planning on 20 psi or more.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old November 13th, 2011, 04:38 PM   #7
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
thats what i needed to know. thanks
Old November 13th, 2011, 04:59 PM   #8
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
The only reason you think that is because cars with lower CR's can run more boost, giving more power. A high compression car at high boost has a high chance of detonation. So the lower the CR, the more potential for boost (you can have high CR and higher boost with meth and/or high octane race fuel or even E85).
So the lower the CR, the better for more boost to a certain point. I think anything under 8.0:1 is pointless in and out of boost and shows no benefits over slightly higher CR.
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old November 13th, 2011, 05:56 PM   #9
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Low compression with boost is old news. The only good thing is with lower compression, you can run more boost and timing without getting detonation. Not much more, but higher compression with more boost will require race gas.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old November 13th, 2011, 06:06 PM   #10
4v Know-it-all
10:1 with 14psi is very safe and can be run on93 octane.
At 14psi an 8.5:1cr combo will be down 50rwhp/50rwtq when compared to a 10:1cr engine.
Threads Similar to: low compression 2v question
Compression Question Mustang02gt 99-04 14 November 3rd, 2011 01:31 PM
compression question fsttang96 96-98 2 October 22nd, 2009 11:57 PM
compression question BoostHard1210 99-04 51 February 6th, 2009 05:00 PM
Compression Question 95blackbeauty 5.0 Mustangs 16 May 5th, 2008 07:35 AM
Question On Compression chadjones99 5.0 Mustangs 4 September 12th, 2006 11:24 AM
