Procharger idle pulley and water pump pulley too close?
Old November 13th, 2011, 11:27 PM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
Has anyone else had this problem? My belt is rubbing between the ati idle pulley and the water pump pulley.
Should I buy a smaller idle pulley? The tensioner seems to be in the right place...
Old November 14th, 2011, 09:31 AM   #2
Picture worth 1000 words?
Old November 14th, 2011, 09:37 AM   #3
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
That is def not right. Im thinking you have your belt run wrong or you have a under drive pulley on your water pump
bone stock from the factory!
Old November 14th, 2011, 10:09 AM   #4
Called procharger... evidentally the idle on a 96-00 is 2.3 while the 01-04 is a 1.95... too bad they didnt tell me this when i called last week and asked the differences between the kits... arg
Old November 14th, 2011, 11:45 AM   #5
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
My first guess is that you have an underdrive waterpump pulley. My installation manual indicates that the 00-04 are the same. The 99 is different. I had the same problem. I couldn't get it to fit because the previous owner put on underdrive pulleys. I had to buy a crank pulley and instead of getting a stock waterpump pulley I bought a Miezere electric water pump. If you only replace the water pump pulley and you leave the underdrive crank pulley then you won't make enough boost. If this is your problem then it has to be replaced. The stock crank pulley is 6.5".
What size supercharger pulley are you running? If I could do it all over again instead of paying for a stock crank pulley I would buy a 10% over drive pulley. But if you are running a small supercharger pulley it would make too much boost.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 14th, 2011, 11:52 AM   #6
Nah the water pump pulley is stock, I believe. I bought an after market crank pulley at 6.5" (stock) since my harmonic balancer was losing its rubber. The idler pulley was just too big...
Going to pull it and replace it this week. I'll dyno tune it friday and let you guys know what I run.
Old November 16th, 2011, 07:26 PM   #7
So I need help... I got a smaller idler puller, the 1.95 but the belt is still touching just slightly... I tried a larger belt than recommended to hopefully bring the tensioner back just enough to clear it, but it's still rubbing... my only option seems to be a smaller water pump pulley??
Thoughts??
Old November 16th, 2011, 07:44 PM   #8
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
try to get a part number off the water pump pulley and make sure its not an under drive pulley.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old November 16th, 2011, 07:54 PM   #9
528-AA on the top, F4SE-8A on left side
Old November 16th, 2011, 09:15 PM   #10
It's stock, I'm pretty sure
Old November 16th, 2011, 10:31 PM   #11
12.73@111.36
I can't tell very well from the picture but your entire bracket appears to be lower than mine. I was wondering if you might be missing a part. There is an offset adapter that attaches to the bottom altenator bolt. The bolt that goes through the ProCharger idler pulley screws into the offset adapter. It raises the bracket and idler pulley up away from the belt on the water pump pulley. Are you using that offset adapter?
Old November 16th, 2011, 10:39 PM   #12
do you have a pic? my kit must've been missing the offset adapter
Old November 16th, 2011, 10:56 PM   #13
yea thats how mine's run... it's just a spacer so everything lines up
Old November 16th, 2011, 10:57 PM   #14
12.73@111.36
It took me forever to scan this but here is a page from my installation manual. The bottom right drawing shows the idler pulley and the offset adapter.
Old November 16th, 2011, 11:09 PM   #15
12.73@111.36
Is is possible that you put the offset adapter on upside down? I still think your bracket is setting lower than mine.
Old November 17th, 2011, 08:49 AM   #16
the offset adapter is just a spacer though, i dont see how that would have any impact on the location of the ati idler
Old November 17th, 2011, 10:07 AM   #17
12.73@111.36
It's not exactly a spacer. The bolt that goes through the idler pulley could have just replaced the one that goes into the altenator brace. But then the belt would rub. Look at the drawing. The idler pulley bolt is above the one that goes into the altenator. The offset spacer raises the idler pulley about 3/8". If it happened to be put on upside down it would lower the idler pulley about 3/8".
Old November 17th, 2011, 10:52 AM   #18
30 bucks, fml... its on the way
evidentally, the mechanic made a spacer
Old November 17th, 2011, 11:08 AM   #19
Because everyone loves pictures:
Procharger:
ATI Pulley and Water Pump, belt is still barely touching with the new 1.95 ati idler:
We tried a bit larger belt, hoping that the tensioner would fall back enough for belt to clear:
Reverse angle (behind the supercharger):
As you can see, the mechanic made a spacer for the ati idler, since it apparently didn't come with the offset spacer.
Old November 17th, 2011, 11:10 AM   #20
12.73@111.36
I hope it fixes your problem. Good luck.
Edit: I do like pictures. I noticed on the installation page I posted that you did need the 1.95" idler pulley.
Threads Similar to: Procharger idle pulley and water pump pulley too close?
Water pump pulley Chris747 99-04 28 August 8th, 2011 03:48 PM
water pump pulley MustGT98allday 96-98 1 April 9th, 2011 08:27 AM
water pump pulley ZoomZoomMFer 4V / SVT 1 August 7th, 2010 11:31 PM
Does this look like a race underdrive crank pulley & stock water pump pulley? STREETFIGHTER50 5.0 Mustangs 8 January 26th, 2010 10:47 AM
