back to the drawing board
Old November 14th, 2011, 01:17 AM   #1
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
went to the track today for the final test and tune for the season. didnt run bad but slower than usual. my 60 foots are killing me with tire spin. i had my 2 step set down to 2100 rpm's and still spinning. after 2 passes i relised my har has a hard time lifting the nose and squating in the back. for now im thinking of gettin strange 10 way ajustible struts for the front, keeping the stock cobra springs, but eliminating the front sway bar. for the back i will be replacing the upr double ajustible control arms for base line pro launch 1's and keeping the upr pro series ajustible lowers with moroso 3 way ajustible shocks. i have fox body springs and if it does not soften up the launch i will be swapping out all the springs for pro launch kit.
any other useful tips on a compleat drag suspension setup for a 10 sec car is apreaciated.
passes on the night.
60----------1.74----1.76----1.69
330---------4.83----4.78----4.82
et@594 ft---6.84----6.81----6.84
1/8et-------7.28----7.25-----7.28
1/8mph-----102.09--101.39--102.02
missed 3rd on the 1.69 sixty foot run
bone stock from the factory!
Old November 14th, 2011, 01:24 AM   #2
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Keep us updated, so it wont be until spring for the next run?
Rock stock
Old November 14th, 2011, 01:29 AM   #3
86er's Avatar
your consistant at least.
I would try one thing at a time, so you can document what made a difference etc as you go
Just a truck
Old November 14th, 2011, 01:35 AM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
unfortunatly its a bad combo. the bilstien struts in the front along with the sway bar keep my nose from lifting, as for the rear, it just isnt squating. the moroso drag shocks are soft along with the fox springs but for some reason the ass end as no give to it. its like the rear end is bound up. i have ajusted it 20 times and nothing helps it. i think its the poly bushings i have in the axle housing.
Old November 14th, 2011, 01:36 AM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
track is closed till feb... i think
Old November 14th, 2011, 01:39 AM   #6
86er's Avatar
Id stat at the front, make those adjustments, then go to the rear. The rear should be wanting to squat with what you have back there, your uppers and lowers the same length, whats the pinion angle?
Just a truck
Old November 14th, 2011, 01:55 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
my lowers are set at 17.5 inches long, my uppers are ajusted so my pinion angle is 2 degrees negative. i ajust my uppers off of 1 upper then i measure off the one to set the other. i do it on a 4 post lift so it should be right but for some reson something is binding up back there keeping my car from squating. im kind of leaning towards the bump stop but i have a decent gap but not as large as i would like. maybe ill cut it down some.
Old November 14th, 2011, 03:15 AM   #8
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
What tires are you using and what size? Do you have a drag bag in the back right? You gotta remember its a lot harder to raise the front end on your car than a 2V bc of the 4V heads and heavy roots style blower sitting up front, and if you have the stock K they weigh a ton over a tubular one. Your 60 foot should be low 1.6-1.5's at least with your power.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old November 14th, 2011, 03:18 AM   #9
2004 Mustang
That's also one reason I love 1/8th mile track's bc you don't have another 1/8th mile to make up for mistakes or an in-efficiant setup on a high HP car.
Old November 14th, 2011, 04:38 AM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
no drag bag in the back. im running a 26x10 hooser drag slicks on a 15x10 wheel. i understand the front end weights more, but the stock cobra bilsten shocks blow for drag use.
Old November 14th, 2011, 07:00 AM   #11
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
I'd call up baseline and see what he recommends for springs, I think i remember both him and dave at teamz recommending stock v8 springs for the rear, apparently they work better then the drag springs. deff get some baseline relocated uppers, and a rear anti roll bar would help quite a bit. along with some better drag shocks/struts. either stranges or even lakewoods would be leaps and bounds better than bilsteins i'm sure.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old November 14th, 2011, 10:41 AM   #12
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
bilstens suck for racing...go with the strange adjustables up front..take sway bar off.. keep the uprs in the rear no reason to change those( i have friends with low to mid 10 sec 6 speed cobras running them with no problems) and get a 28in your tires are to small for a 650rwhp 6 speed car and there you go!!!!!
need any more help shoot me a pm and i will shoot you my number..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old November 14th, 2011, 02:30 PM   #13
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
+1
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Threads Similar to: back to the drawing board
drawing :) maxgst Pictures 30 October 11th, 2010 07:26 PM
Anyone into drawing? unlicensed to drive The Clubhouse 29 May 10th, 2010 10:43 AM
Back the buying board MSTGGT00 99-04 45 May 16th, 2007 04:21 PM
Back to the drawing board scxc15 General Tech 13 March 15th, 2007 02:32 PM
drawing help White99stang Multimedia 22 August 7th, 2006 07:59 PM
