2003 Mustang GT Convertib
How can I tell if i have 4.10 gears?
Bought this mustang a while back its an 03 mustang gt.. its lowered and has an after market clutch and some other mods.. Im just wondering if maybe the gears in it are 4.10... anyway I would be able to tell?
Shake N' Bake
1984 Corvette
Kessel Run @ Less Than 12 Parsecs
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
60 mph should be right at 2,000 RPM in 5th, at least thats how it is on mine, 70 would be closer to 2500
give me a second and ill try to find the gear/mph chart on the site
![]() BONER CREW EMPLOYEE - PACKAGE INSPECTOR #1 |
C Mor Semen
1995 Mustang GT
Not fast enough
Or, they could have written it on the differential. Thats what they did with mine.
![]() MAC CAI, SLP LM1's, Steeda short throw shifter, UPR O/R X Pipe, 3:73 gears, and more to come. |
Shake N' Bake
1984 Corvette
#5 | |
Disturbin' The Peace
2003 Mustang GT
![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Your 5th gear ratio should be .62 because it is 03+
Remember that when calculating anything
![]() 2003 Mustang GT STD 259rwhp 298rwtq
2001 Gt
Easy check. Jack up the axle then spin the driveshaft by hand. If it takes 3.5 revolutions of the d-shaft for one complete revolution of the tire you have 3.55. If it takes 3.73 turns then you have 3.73's. Finally if you turn the driveshaft a little over 4 times to make the tire spin once then you have 4.10's
![]() iTrader: 1 reviews
Jack the car up on jack stands, mark the driveshaft with chalk or a marker. Put car in N and slowly spin the tire 1 full turn while counting how many times the mark on the driveshaft goes around. 4+ a little more is 4.10 gears.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
12.73@111.36
^^This is the only way to be sure. There are too many other variables that affect the speed/rpm comparison. One of which is making sure your speedometer and tach read correctly.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
04 GT
Threads Similar to: How can I tell if i have 4.10 gears?
| Possibly Getting New Gears...THIS IS NOT ANOHER ''WHAT GEARS SHOULD I GET THREAD"! | BC03 | 99-04 | 84 | September 10th, 2011 05:44 PM |
| speedo gears for 4.30 gears | bcinthearmy | 94-95 | 2 | April 23rd, 2009 12:02 AM |
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 12:25 AM |
