FI suggestions
So i had tossed around the idea of going FI even though my motor is 11:1 compression and the general thought on here was to run 4-6lbs of boost and I should be fine and still gain enough power to justify it. so with those needs in mind suggestions on a route? small turbo? blower? i've never FI a motor before but ive built the hell out of N/A motors including the one im running now. I would run an inter-cooler too for the record.
I like boobs!!!
2000 GT convertible
dunno
With that high of a compression ratio heat is going to be your enemy, so I would stay away from a roots or twin screw type blower. That leaves you with two options, centri or turbo. Of the two, I think a turbo is a better choice. I'm sure I'm going to catch some flak for saying that, but that's just my opinion. With a turbo, you will be able to see your 6 lbs of boost by 2500 rpm and hold it through the rpm range. With a centri, if all you're looking for is 6 lbs, you're not going to see it until it's at the top of the rpm range unless you go with a higher boost pulley and have a BOV set at 6 psi which is constantly pissing excess pressure overboard.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
Also, doesn't the type of cams he has come into play?
I like boobs!!!
2000 GT convertible
dunno
Sure does. What are they?
12.73@111.36
Yes, to some extent. N/A cams and FI cams are different but some work with both applications. If I understand it correctly I believe the difference is in the overlap. Too much overlap and the boost goes out the exhaust port at low rpms.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Thats what I was getting at, since he said he's running a built NA motor, prolly has the NA Cams
I like boobs!!!
2000 GT convertible
dunno
You're right about that. On my turbocharged LT1's we ran a custom grind Comp cam with 119.5 degree lobe separation. The idle was so timid but when the boost came on it was a monster. I said this before in an older thread, but when I was doing those engines we had to have Land and Sea come and reprogram our dyno. The turbo would come on so fast that the dyno couldn't keep up with it and the engine would hit the rev limiter before the dyno could apply a load. It was pretty impressive (and crazy) to see.
hmmmmm just throw a 150 pill on it..be cheaper and easier
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
its on the bottle but i want more. the cams are stage 5 N/A anderson motorsport. i dont know the overlap off top but i can call and ask. I actually had two other people suggest turbos first and not knowing a lot i was curious. ill look into the overlap and report back
2001 mustang gt
no clue
Ya at 11:1 id run on juice, ul get way better results
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
I like boobs!!!
2000 GT convertible
dunno
So true. You say it's on the bottle but you want more. Sorry to say but you're not going to get more going FI than you will with some spray at that CR. You're not going to be able to run enough boost to make another 100-150 hp without serious detonation issues. Stick with the bottle if that's you're looking for.
2001 mustang gt
no clue
Ya but u ain't gonna get that much more with fi running 11:1 than u do with nitrous, i just dont think it would b worth spending all that money for minamal gains. I think at the end the only true benifit ul c is that u won't have to keep filling a bottle
hmm well in that case it is what it and i guess we'll leave er at that, thanks guys.
2001 mustang gt
no clue
I'm assuming ur engine is forged? If it is take that money and buy urself a Nitrous friendly intake a And a return fuel system and just spray the shit out it, it b faster and still cheaper
2001 Mustang GT Vert.
Forced induction cams also differ from N/A cams in that they place much more emphasis on the exhaust side. The car has no trouble getting the air into the motor with FI, but it needs help getting all that extra pressure out. Blower cams also benefit in being able to scavenge more heat out of the system due to exhaust emphasis.
What about blower and nitrous???
Mods in garage |
if you want more do a direct ported 200 shot and if you have a fogger now make that a 50 pill(2 stage setup)...so a 250 shot will make you say FI what lol...
#17 | |
12.73@111.36
2001 mustang gt
no clue
To big of a turbo for its application I think possiably does that also
The new 5.0 has 11:1 compression and responds perfectly fine with a supercharger.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
GET THIS. STATIC COMPRESSION RATIO MEANS NOTHING. It DOES NOT matter if hes running 8:1 or 14:1. Dynamic compression is what you need to know. Figure out that and get back to us.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Threads Similar to: FI suggestions
| Any suggestions? | InfamousxHazex | V6 Mustangs | 5 | August 12th, 2010 11:57 PM |
| Suggestions anyone? | ironsteed5.0 | 5.0 Mustangs | 24 | November 9th, 2009 11:50 PM |
| suggestions? | 20mustang07 | Visual | 10 | July 8th, 2009 08:14 AM |
| hey i need some help/suggestions | stangNV | 2005 - 2010 | 6 | August 2nd, 2008 09:02 PM |
| last min suggestions x or h? | thatonekidw/theGT | Modular Mustangs | 18 | July 23rd, 2007 12:26 AM |
