What is this??
Old November 14th, 2011, 12:13 PM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
What is this??
This was in my Procharger kit that I bought...
Old November 14th, 2011, 12:30 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
That, my friend, is the flux capacitor. It's what makes time travel possible!!!
Seriously though, it looks like it's a progressive fuel pressure regulator. It will bump the pressure up in direct relation to your boost so you maintain adequate fuel throughout the rpm and boost range.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old November 14th, 2011, 12:38 PM   #3
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I have no idea what that is. My car doesn't have it. We don't have pressure regulators on our cars.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 14th, 2011, 12:43 PM   #4
It's call a Fuel Management Unit, FMU, but I still don't know what it does... I was reading up and it sounds like it cuts out fuel to increase pressure under boost? lol, idk doesn't make any sense if I have that high flow fuel pump and 42 lb injectors then i dont think i need it
it just came with my used kit, maybe I can sell it??
Old November 14th, 2011, 12:52 PM   #5
I like boobs!!!
2000 GT convertible
dunno
Like I said, it gets a manifold pressure signal from a vacuum/boost line. It has a diaphram inside it that relates that signal and either increases or decreases the fuel pressure accordingly. That way, lets just say you need 30psi fuel pressure. At 10psi of boost, it will increase the pressure to 40psi (40-10=30).
You probably don't need that since your fuel pressure is controlled by the computer. I imagine that whoever had that probably had a carbureted car.
Old November 14th, 2011, 12:57 PM   #6
Ah, so FMUs are for applications that require less fuel pressure to maintain safe air-to-fuel ratios. Wonder what I could sell it for? 25 bucks?
Amazon Amazon
Old November 14th, 2011, 01:02 PM   #7
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Its for a 98 and down Mustang.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 14th, 2011, 01:03 PM   #8
Got it thanks guys... learned me somethin' new today!
