hpx slotted maf vs lightning maf
Old November 14th, 2011, 09:49 PM   #1
joswo1980's Avatar
2001 mustang gt
no clue
joswo1980 is on a distinguished road
Been told to always get the hpx maf over any other maf espeically the lightning but y? Some questions have been raise y the hpx maf is better, I've been told they r both just as accurate recently and the lightning maf with a Mafia is even more accurate .just wanna know for future informational purposes, thanks
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
Old November 14th, 2011, 09:53 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
hpx maf is better in a blow threw, it has a much cleaner resolution. there is nothing wrong with a lightning maf, but when it comes to blow threw the hpx is light years ahead of it. one of the advantages of a hpx maf is its range in tight spaces. a lightning maf does not do well in any other housing other than the 4" housing it comes in, where the hpx maf can be installed directly to a 3 inch pipe with little change. if you plan on staying draw threw a lightning maf can be a cheap alternative, but a hpx maf saves money over buying a lightning maf and a mafia when going blow threw
bone stock from the factory!
Old November 14th, 2011, 09:55 PM   #3
joswo1980's Avatar
2001 mustang gt
no clue
But in a blow thru configuration is 1 more accurate than the other?
Old November 14th, 2011, 09:57 PM   #4
joswo1980's Avatar
2001 mustang gt
no clue
Would I see a better tune with one or the other? And y?
Old November 14th, 2011, 09:59 PM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
yes the hpx is more accurate in a blow threw setup. also a lightning maf will peg extreamly early in a blow threw app if the maf is put in a smaller diameter pipe to fit the rest of the ic pipe. i pegged my lighting maf in a 3" housing with a mafia at 500 rwhp. a hpx maf will support around 600 rwhp in a blow threw setup in a 3" housing without a mafia with a mafia that maf will support over 1000 rwhp.
Old November 14th, 2011, 10:01 PM   #6
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
What does a bap have to do with the maf? lol
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old November 14th, 2011, 10:02 PM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
there is always more to a maf than what power it can support. imo a maf is one of the most imortant choices to make when building a fi car. the better the maf the better the low speed driving. having a smooth clean resolution will make the car drive like stock. if there is a lot of distortion it will be felt at part throttle.
Old November 14th, 2011, 10:03 PM   #8
The LMAF with a mafia when mounted correctly will provide a very clean signal. The HPX is almost idiot proof though as far as mounting configurations. It is very resistant to backwash and signal noise of any type. Neither maf will produce more HP though. The HPX has more range because it can be mounted in larger side tubing but all in all for a vehicle under 500-550rwhp both when setup correctly will provide similar results
Old November 14th, 2011, 10:04 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
sorry i ment mafia, i was typing fast
Old November 14th, 2011, 10:11 PM   #10
joswo1980's Avatar
2001 mustang gt
no clue
So if both have similar results then i basically wasted 300 between sensor, flange and pigtails for something I coulda done with 90 bucks???
Old November 14th, 2011, 10:14 PM   #11
No you will need a mafia to use the LMAF with a higher HP. The HPX gives you alot more to grow with and will work better in a less than opimum location than an LMAF would have
Old November 14th, 2011, 10:41 PM   #12
For a draw though configuration I almost always recommend the LMAF for starters. Its cheap to get most guys started and when the raise the boost they can just add a mafia. For blow though I go for the HPX because its super easy and clean to mount. The fact that you dont need a maf housing is a huge plus. I personally like using the 75mm maf housings in blow though apps and even a 75mm housing in draw though with the HPX for most builds. The maf still has enough range in a 75mm housing to support over 600hp which is plenty for most people. Running it in a smaller housing is what gives you all that resolution for great tuning and part throttle driving. Toss it in a 90mm or 100mm housing and the signal gets choppy VERY quick.
Old November 14th, 2011, 10:41 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
trust me you did not waste your money. i have tried 3 diff lightning maf setups and non of them could compair to running a slot maf. in a blow threw setup a hpx maf gets rid of the need for reducers and additonal couplers. from a dd stand point the hpx maf will allow the car to drive as it did when it was stock. with a lightning maf i constantly had bucking and serging which sucked.
Old November 14th, 2011, 10:56 PM   #14
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
I have a lightning maf in a draw thru setup. When I add the intecooler I will be converting to blow thru with an hpx maf.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old November 15th, 2011, 12:04 AM   #15
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I'm running the stock MAF and MAFia. I didn't need reducers, etc. Actually with the ProCharger kit it was just another plug in device. (Note: Of course I needed a dyno tune. The MAFia changed all the parameters.)
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 15th, 2011, 01:05 AM   #16
I think it comes down to this. They can both be a good maf. The LMAF takes a better setup to work as well but they can work very well with a mafia.... Now they are so cheap to boot. If its your 1st blower setup and your on a budget and shooting for under 450hp the LMAF may be your ticket. If your building something and you know you want to grow in the future you cant beat the HPX because its range can be increased just by changing the housing ID. I've ran both and they both worked well. I had zero driveability problems with either but the LMAF did take a little more tweaking but when done I couldnt tell any difference with either.... at least 50% of maf performance isnt related to the maf at all. Its related to the tuner, and the setup. By this I mean having enough pressure relief (BPV,BOV) and configured to work correctly with the maf application.
Old November 15th, 2011, 07:52 AM   #17
joswo1980's Avatar
2001 mustang gt
no clue
Ok I think I understand now why I was told id get a more better and more accurate tune with a hpx cause I'm using a 4 core intercooler but the info dosent apply to all setups in which some setups the lmaf could b equally as good
Old November 15th, 2011, 10:45 AM   #18
The intercooler doesnt really have anything to do with it.... The HPX would be better in that app because you dont need the extender (less parts), easier mounting and enough maf to grow rather large with before changing anything.... They both work but the HPX tends to work better in a variety of apps because its not very sensitve to install.... put a LMAF right before or after a bend and you'll have major issues... not the case with the HPX. I think most tuners recommend them because no matter where the car owner mounts them they tend to work pretty well. So even when installed incorrectly the tuner has a good chance of being able to tune it still. If you install the LMAF wrong the tuner either has to fix your problems because he cant tune or turn you away and set another date after you fix the maf placement.
Old November 15th, 2011, 11:13 AM   #19
joswo1980's Avatar
2001 mustang gt
no clue
Ya that's probably y I was told to get it cause the cx is a diy kit and he probably figured no matter how I run the pipes or where I put the hpx I still got less of a chance of fuckin up lol
Old November 16th, 2011, 08:20 PM   #20
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
I had a lmaf on my car with a zone 5 extender and it caused all kinds of aggravation. It caused my car to go lean so the tune had to be scaled for it, meaning it could have made more power with the right maf. I was on the edge of switching to a slot style maf when i sold my car. Be glad that you went ahead and got the good stuff.
Threads Similar to: hpx slotted maf vs lightning maf
Drilled/slotted rotors yellowsilver 94-95 10 April 22nd, 2011 11:10 AM
Drilled, Slotted, Or Both? brharris777 4V / SVT 24 May 13th, 2010 07:21 PM
slotted brakes oannamarie 96-98 3 August 24th, 2009 10:02 AM
Slotted Or Drilled Or Both? chris1 99-04 7 December 7th, 2007 08:10 AM
Slotted vs Drilled TheBusher 99-04 23 November 13th, 2007 12:08 AM
