#21 |
2000 gt
i'm assuming matt you're running an anderson since no one else really made one. house of boost made one for a short time period but have stopped from what i can tell. plenty others make their own.
i have an anderson
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
#22 |
11.463@121.50
Thanks for doing that experiment.
Keep in mind, when you get the car tuned, if the engine is running too lean with the powerpipe, you might lose a few hp after the tuning (adding fuel)... As far as the weather is concerned: I was trapping around 117.50 MPH in July (high 80s and high humidity), and now 121.50 MPH in November (mid 50s and about 50% humidity). And F yeah, I can feel the difference!
MM Bracket Racing Crew Member #5 |
#23 | |
2001 Mustang GT Vert.
Nice to know that it did make a difference though.
Mods in garage |
#24 |
The Mean Green
Yea its an Anderson, I gaind 2-3 psi with it.
#25 |
The system shouldn't lean out at all in either a blow through or draw though app. Thats what the maf is for. If the maf is calibrated correctly the fuel mixture will remain constant as the maf voltage increases from the increased volume of air. The only condition that would cause the AFR to lean is if the new power pipe was enough to cause the maf configuration to peg.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
#26 |
2000 gt
so what about pulley swapping? would you say jumping down a pulley size would be safe because the maf could make up for it?
i personally would not risk that. i've always been told retune is necessary after a new mod.
Threads Similar to: Before and after dyno runs with a powerpipe
| Video of my m90 all done (dyno runs etc) | quadracer786 | 2005 - 2010 | 17 | November 3rd, 2010 11:09 PM |
| Brooksspeed vs Bama dyno runs | gragra73 | 2005 - 2010 | 9 | October 11th, 2009 09:25 PM |
| stock dyno runs | Devine | 5.0 Mustangs | 24 | January 31st, 2008 01:16 PM |
| Jan 19th Ft Myers - VMP Mobile Dyno - show, dyno runs and tuning by appointment | Justin00Stang | Southeast | 0 | January 4th, 2008 07:26 PM |
| dyno runs | ozan169 | 2005 - 2010 | 1 | February 4th, 2007 11:37 AM |
