Chitty Chitty Bang Bang
2001 Mustang GT
![]() ![]() iTrader: 2 reviews
Slight vibration while idling - not sure what it is?
So since I can remember on this car, I've had this slight vibration at idle. I've noticed when I first start the car and come to a full stop or red light, the RPMS stay right at 1000k; however, when I start driving a bit and get the motor warm at a stop light the RPMS drop to normal 600-700 at idle. At the higher RPM the car idles fine, but when it idles at 600-700 rpm the car shakes a bit. The rpms stay dead constant, but there's this vibration or shake. What could be causing this, and what tests should I run? I've tried
-New IAC -Replace back stock intake -New upper intake (old was plastic and cracked at thermostat) -New plugs -Checked for vacuum leaks -New COPS
2001 Mustang GT 5-Speed ![]() God Created Man, but Sam Colt Made Them Equal |
I had that problem and it was my headers rubbing on the floor pan. Anything between the motor and chassis could cause some vibration. Have you checked the motor mounts?
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
2001 Mustang GT
It's not a vibration on just the floor pan but a vibration of the whole car. It's like a side to side sway type vibration that can really be felt in the shifter. How exactly do I know if the engine mounts are bad?
2004 mustang GT
![]() iTrader: 7 reviews
Check your harmonic balancer my wifes explorer was doing the same thing and the balancer was coming apart
Flowmaster super44's, 70mm frpp TB, C&L plenum, K&N cai,UDP,SCT SF3/X3, TR3650, short throw shifter, Mac O/R H pipe Waiting to install vortech v2 s trim |
2002 mustang gt
![]() iTrader: 1 reviews
Could it be misfiring? Headers againt floor? Bad motor mounts, solid motor mounts?
Rock stock
2002 mustang gt
Oh you said you can feel it in the shifter so it couldn't be solid motor mounts but it could be bad mounts
Rock stock
Threads Similar to: Slight vibration while idling - not sure what it is?
| Excessive Vibration While Idling From 1998 Mustang That Was In Storage | FlyForce | V6 Mustangs | 18 | May 18th, 2010 02:46 PM |
| Slight lag? | idesigner | 4V / SVT | 7 | March 8th, 2010 01:30 PM |
| slight vibration at high speed? | 91cobra5.0 | 5.0 Mustangs | 3 | June 22nd, 2008 08:38 PM |
| Slight Vibration | Boris | 94-95 | 7 | February 12th, 2008 01:58 PM |
| Slight vibration at 90mph | PaperCross | 2005 - 2010 | 24 | June 7th, 2007 09:07 PM |
