2000 mustang gt
13.7 @102
timing chain kit question.
I'm looking around for these timing drive kits with new chains and tensioners. and i found kits that seem to be fairly priced on latemodelrestoration. However, the cloyes kit is for 96-98. the trickflow is for 96-04. and ford racing is only shown as 01-04. is there a misprint here or is there a detail im missing out on? i dont mind buying trickflow stuff i have faith that they make quality parts, but why would the others not be available for a 2000 gt also? ive noticed as the car gets more miles it seems to be getting noisier so im trying to restrore my motor and avoid damage. im at 116k now
2003 Mustang Fauxbra
N/T @ Fast
The difference is going to be for the cam gears.... some are pressed onto the cams and some are bolted on. Whatever you do, don't install the plastic tensioners..... find a kit that includes steel tensioners. I'm not a fan of plastic.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
2000 mustang gt
13.7 @102
so trickflow was the only company to make cam gears to fit both press and bolt on styles? and which companies have the steel tensioners? there isnt a clear cut description about this.. the pic for trickflow looks like plastic and ford racing looks steel.. but again there is no ford racing or cloyes option for a yr 2k car
N/T @ Fast
The tensioners are the same for 92-current on the 2V motor. I'd go with Ford if they offer them in steel. If you want to buy a different kit go ahead and just order two Ford tensioners.
#5 | |
2000 mustang gt
13.7 @102
just a thought here please disregaurd.. WHY DONT THEY MAKE MAINTAINANCE EASY?!?!
You honestly don't need to change the gears. I've never seen a set worn out even at 300k miles. Just order up a new set of chains and guides from MHS and leave everything else original. The tensioners will be good 99% of the time. The iron ones with the locking mechanism are the ones to have. If I was you I would order up the guides and tear it down. If the original guides arent worn to the metal then just leave the stock chains. Most people never change them. My buddies cobra has been running the stock ones for 150k miles and we just rebuild it and used them again. When compared to a new set of chains there was no wear. Amazing I know but this isnt a pushrod motor your working on. The only chains I've seen break are ones thats been ran all the way through the tensioner and into the oil pump
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
N/T @ Fast
You can buy the steel tensioners from the parts counter at any Ford dealership.
#8 | |
2000 mustang gt
13.7 @102
N/T @ Fast
Modular Head Shop
Google it.
00 Mustang GT Vert/88 5.0
I bought my steel tensioners from Advance auto and all of my other timing components.. When you get ready to pull your cover let me know I tried a different tecnique last night that took me about 20 minutes the have the cover off.. Like nighmare said you just need to replace your chains, tensioners, and guides cam gears should be just fine.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
![]() iTrader: 1 reviews
Good to know and I am going to check my local parts store today.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
2000 mustang gt
13.7 @102
thanks for all the input guys! ill be looking at modular head shop
#13 | |
2000 mustang gt
13.7 @102
I would stick with the plastic ones. Sometimes the metal ones wont work on windsor motors due to the block not be drilled in all the needed locations.
Threads Similar to: timing chain kit question.
| timing chain question | 06invertmini | 99-04 | 3 | May 21st, 2011 12:30 PM |
| Timing Chain Question...HELP!! | sstang02 | 99-04 | 10 | November 30th, 2010 11:42 PM |
| Timing Chain Question | sstang02 | 99-04 | 8 | November 14th, 2010 10:43 PM |
| Timing Chain Tool Question | ryan76 | 99-04 | 6 | August 4th, 2010 04:50 PM |
| Stock timing chain question? | jam77 | 5.0 Mustangs | 8 | October 30th, 2007 11:04 AM |
