#1 | |
2003 mustang GT
never tried
![]() iTrader: 5 reviews
do i need a pulley puller to take the timing chain cover off?
im sure im going to need some sort of pulley remover in order to remove the timing chain cover, can anyone point me in the right direction? thanks guys
06 mustang GT~ Totaled 11/12/10 03 mustang GT~ Daily Driver WTB: Saleen Bumpr |
![]() iTrader: 1 reviews
A pulley puller would be needed for the harmonic balancer, and you can find one at just about any auto parts store.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
I like boobs!!!
2000 GT convertible
dunno
I was able to wiggle my old harmonic balancer off without a puller when I tore down my old engine. Scary huh?
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
#4 | |
2003 mustang GT
never tried
thanks guys, nick thats nuts lol
and when LRS says left head or right head... is left the P/S head? or is left the D/S head
I like boobs!!!
2000 GT convertible
dunno
Thats a good question. I would guess left side of the car, so driver side.
1999 GT 35th LE
You can go to an Autozone and rent the harmonic balancer puller and install tools. When you return the tools they will credit your card for 100% of the rental so you are renting them for free.
You will need 2 different tool kits, 1 kit is the puller, the other is the installation tool. A little bit of advice for you, get a piece of cardboard and cut it in the shape of your timing cover. As you remove the bolts from the cover, take a phillips screwdriver and push a hole in the cardboard and push the bolt into the cardboard in the position they came out of the timing cover. The bolts are different sizes and lengths, and if you do this you won't be confused on where each bolt goes when reassembling. It also helps to keep from losing a bolt or washer. Other bolts I remove I place in a sandwich baggy and label the bag so it makes reassembly a piece of cake. Have a small box handy to throw all the sandwich bags in to keep from losing stuff.
![]() Drive it like you stole it Last edited by 99GT35thLE; November 16th, 2011 at 11:28 AM. |
#7 | |
2003 mustang GT
never tried
wow dude thats such a smart idea, thanks for that. def will cut that piece out. and sounds good im gonna head over to autozone and inquire about those tools.
im looking at replacing the d/s head.. so im gonna buy these three kits/parts 1999-04 Mustang 4.6L 2V LH Ford Racing "Pi Head" Cylinder Head, M-6050-P46 at LRS - Same Day Shipping! 2001-04 Mustang 4.6L 2V Ford Racing Camshaft Drive Kit Cast Iron Block Applications, M-6004-462V at LRS - Same Day Shipping! 1996-04 Mustang 4.6L 2V GT Ford Racing Head Changing Kit, M-6067-D46 at LRS - Same Day Shipping! ANYTHING ELSE you guys would recommend buying to make my job that much easier? i have valve cover gaskets so thats covered. thanks all.
1999 GT 35th LE
The head changing kit you have listed does not have the intake manifold gaskets. There are other kits available that has the intake manifold gaskets and other gaskets included.
Since you are removing the timing cover I would go ahead and buy those gaskets as well. Would suck to get it all back together and have the crankshaft seal start leaking because you would have to remove the timing cover to replace the seal. Better to do things right once, then to have to do it over again.
![]() Drive it like you stole it |
#9 | ||
MM's king of Neon's
404 - car not found
17.81@87
![]() Want to trade balancers with me? I have the opposite problem. I marred some threads taking it off, and snapped off a bolt putting it in. Though using your balancer would make it kind of tough for me to use my supercharger pulley. ![]() You'll want to have a welder's paint marker handy. When I did my cams I labeled each component "L" and "R" as well as marked my timing gears/chains. The paint markers are like $3, I got mine at Rural King in the welding section. It's also handy for marking which bolts you have already torqued, just like the pros.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
Threads Similar to: do i need a pulley puller to take the timing chain cover off?
| timing chain cover | KevinJ99GT | General Car Care & Detailing | 3 | July 28th, 2011 03:12 AM |
| timing chain cover | bullitt5576 | 99-04 | 1 | July 19th, 2009 02:13 PM |
| 302 Timing chain cover | 707Stang | Classic Mustangs | 5 | December 10th, 2008 10:28 AM |
| timing chain cover | mpboy | 99-04 | 3 | March 16th, 2008 10:10 PM |
