LinkBack (1) | Thread Tools |
#1
leak near my upper radiator hose...help please
i was getting a quote for my hood painting and when i lifted the hood i noticed some white gunk on the part my upper radiator hose is connected to. I am new to working on and diagnosing my own car so I could use some help please:
1. what is the part the hose connects to? 2. what could be causing the leak? 3. how can it be fixed? here are some pics, thanks guys... ![]() ![]() ![]() ![]() ![]()
![]() iTrader: 1 reviews
Looks to me like your upper hose. In the picture you have White dried scum around the hose and it will leak down and scum up the rest of the parts below it. Just my .02
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
I hope that's all it is, but idk...I'm going to clean it off and then see if it comes back at all. There's no focal location though, if it was all from the hose I think you'd see it piled up in one spot more right?
That part the hose connects to is the thermostat housing. It's a bit hard to tell exactly where it is leaking from the pics, I would clean all the gunk off and drive it around and see if you can tell where it's coming from
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
1999 GT 35th LE
You can try and tighten the 2 bolts on the thermostat housing, but from the way it looks in the pics I think you have a leaking manifold gasket.
The thermostat housing has a rubber O-ring where it meets the intake manifold. Most coolant leaks occurr at the manifold gasket.
![]() Drive it like you stole it |
#6 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/239639-leak-near-my-upper-radiator-hose-help-please.html
| Thread Upper Radiator Hose Leak | Ford Explorer Ranger Enthusiasts Serious Explorations® | BoardReader | This thread | Refback | April 26th, 2012 07:37 AM | |
Threads Similar to: leak near my upper radiator hose...help please
| Want to change out my upper radiator hose but have a question... | tinkerbell_too | 99-04 | 19 | November 9th, 2010 12:12 AM |
| upper radiator hose | Yur2slo | 2005 - 2010 | 17 | December 30th, 2009 03:36 PM |
| Radiator Hose | nHuman | 96-98 | 3 | October 2nd, 2008 05:19 PM |
| metal radiator hose? | 91cobra5.0 | 5.0 Mustangs | 7 | May 25th, 2008 04:01 PM |
| 01 stang gt Radiator Hose Kit ? | RanGer498 | 99-04 | 0 | March 1st, 2008 07:31 PM |
